rorynate
1974 D-200 speed/gear shift help needed
rorynate
Hey everyone new to the site here.  A couple of months ago I purchased a 1974 D-200 with front and rear pto rear 3 point.  I put it to work right away.  I was grading driveway last week when the speed control arm I call it snapped a bolt or pin.  Now I can not figure out how to fix the arm,it just hangs in neutral.  And the 200 is sitting in the yard unmovable.  I can not find the part anywhere.  I call the speed control arm the lever that is forward reverse etc.  Do not know the proper name.  Can I just weld the arm back in a certain position?  Any help would be appreciated  Thanks  rorynate.
Edited by rorynate
need help
stevasaurus
Here is the trans manual for your transmission.  Take a look at pages 22 and up.  Page 24 gives a good picture of how it works and parts.  :)
If you did not know...you should have the Sundstrand #90-1137 transmission.
rorynate
Thanks stevasaurus.  I have found the link to all the parts and all the manuals I now have downloaded on the 1974 D-200 K532 .  I know the part # I need even but I can not find the part anywhere.  I called Toro even and they quit MAKING THAT PART AVAILABLE MORE THAN 18 YEARS AGO.  I DO NOT EXACTLY UNDERSTAND HOW THE SPEED CONTROL ARM WORKS OR I WOULD DO A TEMP WELD OR SOMETHING UNTIL I CAN FIND THE PART ON CRAIGSLIST OR EBAY.  I JUST DO NOT UNDERSTAND HOW THE SPEED ARM CAN BE HELD TOGETHER BY A LITTLE PIN WITH A COTTER TO HOLD IT IN PLACE.  LIKE THE DIAGRAM SHOWS.!!!!!!!!!  tHANKS RORYNATE
stevasaurus
I am not familiar with that horse, just pretty good at finding information.  Some will be along that will know how to fix what you have.  :)  Check the manual for the tow valve.  Open that and you can roll or tow it out of the yard.  :handgestures-thumbupright:
82Caddy
I can get a picture or two this evening of my d200 or d180 shift parts if you don't have a solution sorted out by then.
gwest_ca
This 1978-89 B, C and D-Series service manual may have some info to help. Much of the content applies to all models.
Garry
daveoman1966
What is the broken part you are looking for..... item #  from this schematic:
rorynate
Part # 6-35 is the part that broke or ended up in the gravel in my driveway buried somewhere in the whiterock.  I can only see the pin missing from the parts breakdown.  The shifter just sits loose in between the two brackets.  The spring assembly is still seated.  Thank you DAVEOMAN1966
rorynate
I found the pin sheared off sitting inside of the hand control arm.  I knocked it out with a small tapping chisel.  Now I have to find the part or have a machine shop maybe make me one the exact dimensions.!!!!!!!!!!!
pacer
If its the pin I'm thinking of - mine broke one time and as a 'make-do' I put a big nail in it thinking "I'll replace it later" - well, 4-5 years later when the nail finally wore through that mild steel, I fixed it!:rolleyes:
KC9KAS
@rorynate :WRS:
Don't just "weld" something until you know exactly what you have and need.
psalms83:18
put some pics up!! We like pics! Even if they aren't the best pics it can help us make better brainstorms!
