Hodge71
42" RD Deck: Help Identifying!!
Hodge71
So what I do know is its a 42" rear discharge. It came on a 1979 C-81 I got from my neighbor. What I don't know is what year? Is it possibly a 1979? The 1979 manual doesn't show that form of height adjustment. No id tag, original paint. Height adjustment like I've never seen before on a horsey. I know its definitely a WH deck the problem is I need to know the year and number so I can download a manual and parts list. Its been a rough 3 weeks on horses here. I have 2 42"RD and a 48 SD and every one of them is broken. I bent the shel on the 48 cutting with the GT-14. Its pretty well useless until I get time to heat and beat and rebuild the entire thing. One 42" RD succumbed to a very large metal stake in the ground that bent the center spindle, shaft, deck shell and blade. That left the lowly unknown 42RD in the picture that spun the bearing in the center deck spindle and possibly wiped the shaft out. Needless to say I need to spend some serious cash to get everything back up and running once I get part numbers
elcamino/wheelhorse
Looks like the lever for the height adjustment is missing.
daveoman1966
Me thinks your deck model is 05-42XR01   (up thru -05) and the spindle shafts are probably those that use a keyway slot in the spindle shaft / pulley.  I have replacement spindles for your deck, as well as the missing height adj  lever and spring mentioned earlier.  Even if you spindles do NOT use the keyway, I have that style too.
for further details, send me an OFF-FORUM email.  my email is:
daveoman@windstream.net
Hodge71
I figured that much out on my own..lol..I needed the model number which I believe Daveoman may have successfully provided. I will know once I locate the manual
Hodge71
Well I found the manual for 05-42XR01   and downloaded it. Its for 1980 B series tractors. Definitely not the pulley arrangement mine has, and the deck hangar linkage is definitely for a C-series. I haven't taken it apart and doubt I will be able tonight but I'm more confused now :think:
gwest_ca
Try searching the files for "42MR01" "42MR02" and "42mr03" in quotation marks. With so many parts lists shared between models many of the illustrations don't match the actual model number. If you can find an original IPL it may be correct. The TIPL's are a problem. These come from Toro online.
Garry
Hodge71
Thanks Garry. That little tidbit led me to 85-42MR01.It seems as if this one is correct. Its basically the same as my 1974 42"RD except for  the height  adjustment gauge.I wonder why they went with such a complicated set of plates and levers when the old system worked just fine? Now to get prices on parts
elcamino/wheelhorse
Sorry did not mean to upset you. First thing I noticed . What parts are you looking for?
Hodge71
You didn't upset me at all El Camino. I need the deck height adjustment handle and assorted hardware, spring that goes with it and Im sure spindle bearings once I get into the center spindle. Plus bearing and shaft for my other 42 RD center pulley, not to mention deck anti- scalp rollers, wheels  and god only knows what else for my 48 from the GT-14...Its gonna be expensive.
Edited by Hodge71
elcamino/wheelhorse
Are you going to Big show ? I may have the handle and spring.
Hodge71
Absolutely! Gotta pick up a 10 horse Kohler and some other goodies. I'll be there Thursday after work, Friday and possibly Saturday morning.
elcamino/wheelhorse
I will you know what I have and we can meet at the show. I'll be at the Comfort Inn in Chambersburg some time Thursday afternoon . May ride over to show location that day , but I will be there on Friday and part of Saturday.
elcamino/wheelhorse
I have not forgotten you just been to busy with Honey Do's and vet visits. I have an almost new handle , rod assembly minus the wheels . It came off of a 36 " rd deck , I will try to measure with a photo to see if it will work on your deck. Should have  all information by tomorrow. Sorry for the delay.
