ricksrj58 279 #1 Posted June 6, 2016 i picked up a nice 5000 watt generac alternator model 6511-1 for $60 at centre hall over the weekend.i was told i would need a 12 horse or larger to use it,is that right? it did not have a tractor mount with it so if any one can post a pic or two of the mount and how it adjusts the belt tension i can fab one up. thanks.. 5 Share this post Link to post Share on other sites
WHX?? 58,307 #2 Posted June 6, 2016 This stuff came with a 520 I got awhile ago. The bracket on the right appears to get mounted on the front attachmatic mount and it runs right off the pto. I have no idea what the bracket on the left is for. I also have no idea what tensions the belt yet as I have not had the time to play with it yet. At 5 kw a 10 hp should run it but 12 would be better. What tractor do you plan to use it on? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,511 #3 Posted June 6, 2016 Have you looked through these? http://www.wheelhorseforum.com/search/?type=downloads_file&q=generator Garry Share this post Link to post Share on other sites
ricksrj58 279 #4 Posted June 6, 2016 i have a 310-8 i can put it on and use when i get a mount made.i also have a c-81 repowered with a 12 horse kohler but i need to put all the pto parts on it and not sure if i have what i need. Share this post Link to post Share on other sites
wheelhorseman 3,256 #5 Posted June 6, 2016 Not mine just some pictures that might help you out 3 Share this post Link to post Share on other sites
squonk 48,219 #6 Posted June 6, 2016 (edited) Here's a Gen U Ine Generac on Marvin. with a home made mount. The bolt you see sticking out in the front goes thru a welded on nut for the tension I'll have that Jenny on my C-160 at the show. I have run it on my 73 12 also. Edited June 6, 2016 by squonk 1 1 Share this post Link to post Share on other sites
ricksrj58 279 #7 Posted June 7, 2016 Cool, i will have to look at it. Share this post Link to post Share on other sites
Bill Winn 157 #8 Posted July 21, 2021 On 6/6/2016 at 6:05 PM, squonk said: Here's a Gen U Ine Generac on Marvin. with a home made mount. The bolt you see sticking out in the front goes thru a welded on nut for the tension I'll have that Jenny on my C-160 at the show. I have run it on my 73 12 also. That is a sharp paint job. Well done! I'm the new owner of a c-175 and I think I will put a lot more linen white on mine when I paint it. May I ask, did you body fill and block sand or did you just prime and shoot? Share this post Link to post Share on other sites
squonk 48,219 #9 Posted July 21, 2021 Just sanded to bare metal. 1 coat of etch primer, and 1 coat of primer sealer. Share this post Link to post Share on other sites
cschannuth 3,821 #10 Posted July 21, 2021 On 6/6/2016 at 11:56 AM, ricksrj58 said: i have a 310-8 i can put it on and use when i get a mount made.i also have a c-81 repowered with a 12 horse kohler but i need to put all the pto parts on it and not sure if i have what i need. I usually run my 3,000W on a 314-8 but my 6.5 HP Predator runs it easily. Plus it will run for hours on a gallon of gas. Share this post Link to post Share on other sites
Handy Don 17,565 #11 Posted July 21, 2021 12 minutes ago, cschannuth said: I usually run my 3,000W on a 314-8 but my 6.5 HP Predator runs it easily. Plus it will run for hours on a gallon of gas. Rule of thumb on generators is 2hp per 1000 watts. 1 Share this post Link to post Share on other sites
Gregor 4,848 #12 Posted July 22, 2021 On 6/6/2016 at 5:05 PM, squonk said: Here's a Gen U Ine Generac on Marvin. with a home made mount. The bolt you see sticking out in the front goes thru a welded on nut for the tension I'll have that Jenny on my C-160 at the show. I have run it on my 73 12 also. That is a nice looking set up. I don't know what I would do with a generator, but would like to have one anyway. Share this post Link to post Share on other sites
cschannuth 3,821 #13 Posted July 22, 2021 6 minutes ago, Gregor said: On 6/6/2016 at 5:05 PM, squonk said: That is a nice looking set up. I don't know what I would do with a generator, but would like to have one anyway. You never know when you might need a generator but having the discipline to exercise the engine regularly to make sure it starts when you need it can be a challenge. Having one that is powered by a WH is nice because the tractor gets used regularly so it should start when needed. Plus it can install on any attach a matic tractor. I store my generator on a cheap 4 wheel dolly so it only takes about 60 seconds to roll it in to place, latch it in, and hook it up. Share this post Link to post Share on other sites
c-series don 12,524 #14 Posted July 22, 2021 Here’s my C-121 Automatic with 3000 watt generator 1 3 Share this post Link to post Share on other sites
Gregor 4,848 #15 Posted July 23, 2021 I could buy my wife a 110V electric lawn mower, and follow her around the yard. 3 Share this post Link to post Share on other sites
Tuneup 1,459 #16 Posted July 24, 2021 With a gen, it's all about the loading. If you are bringing it on a picnic so the kids can keep their phones charged, an old 3HP Briggs would have been enough. The water heater? More power! Share this post Link to post Share on other sites
pfrederi 21,222 #17 Posted July 24, 2021 (edited) 2 minutes ago, Tuneup said: With a gen, it's all about the loading. If you are bringing it on a picnic so the kids can keep their phones charged, an old 3HP Briggs would have been enough. The water heater? More power! I don't ever remember taking a generator on a picnic for that purpose...Times have changed... I thought kids were supposed to run around and play at a picnic Edited July 24, 2021 by pfrederi 1 Share this post Link to post Share on other sites
Tuneup 1,459 #18 Posted July 24, 2021 Definitely! I'm a flip phone owner - no phones on a picnic! That said, could any kids today be without them for more than an hour? 1 Share this post Link to post Share on other sites
Handy Don 17,565 #19 Posted July 27, 2021 On 7/24/2021 at 9:54 AM, Tuneup said: Definitely! I'm a flip phone owner - no phones on a picnic! That said, could any kids today be without them for more than an hour? I'm only good for a few hours max between phone checkups and, frankly, I like having it nearby even if I'm not using it. Share this post Link to post Share on other sites
