hondagod64 81 #1 Posted June 6, 2016 I HAVE A 79 C-121 8 SPEED [ 91-12K802 ] WHEEL HORSE THAT THE CHOKE CABLE BROKE AND THE THROTTLE CABLE IS BINDING. WHEN I LOOK UP THE REPLACEMENT PART NUMBERS FOR BOTH CABLES THROUGH RCPW AND PARTS TREE THEY SHOW TWO DIFFERENT NUMBERS. CAN SOMEONE TELL ME WHICH PART NUMBERS ARE THE RIGHT ONES FOR MY TRACTOR. JUST WOULD LIKE TO ORDER THE RIGHT ONES.... THANKS Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,008 #2 Posted June 6, 2016 There is a link to an original parts list in this one The reason you find two part numbers in the online parts lists is the lists are shared by similar models and in this case likely a twin-cylinder model. If you don't find what you need let us know. Garry Share this post Link to post Share on other sites
hondagod64 81 #3 Posted June 6, 2016 THANKS AGAIN GARRY...I FOUND THE RIGHT PART NUMBERS THAT I NEED...FIGURES THAT THEY WOULD BE THE MORE EXPENSIVE ONES....BUT THANKS FOR YOUR QUICK RESPONSE Share this post Link to post Share on other sites
