Brad Johnson
Eaton 11 brake spring needed
Brad Johnson
Good Saturday Morning,
I am new to this forum; my tractor is the Work Horse GT-1800, the B&S V-Twin variant of the Wheel Horse line. Has an Eaton 11 tranny. I have been having braking issues for some time; pressing the brake pedal does put the transmission into neutral, but holding power has been a problem. I took off the side panel to check for an adjustment of the brake rod, only to find a PO had replaced the spring (called "heavy spring" in the manual) with thick washers, which gives me no way to fine tune this brake. The spring is listed in the Eaton schematics as "Item 11, spring" but no real part number. Can anyone suggest a parts source and part numbers for these units?
Brad
JPWH
I can't help you with your problem but I can say :WRS:. Someone will be along that can help you though.
WNYPCRepair
I can't find anything for your model, but this is the parts list for a 520-H, I think it is probably the same spring. Item 11, $6
https://www.torodealer.com/en-US/Pages/parts.aspx?Model=73501&Serial=39000001&MYBEID=5415&PageId=309408&IllustrationId=300269
gwest_ca
Would the spring be on one of these pages of the IPL?
Garry
AMC RULES
:WRS:
Brad Johnson
WNYPC, you nailed it! That is exactly I need. And, I'm just a stone's throw away in the Finger Lakes - thanks, man!
Brad
WNYPCRepair
yeah I just verified the part number with the other arts list Garry found and it is the same part
I'll be heading down by Cortland around the first week of July to meet a guy buying a deck
Brad Johnson
I'm much closer, near Naples. Good luck with the deck!
Brad
  • Similar Content
    • CasualObserver
      By CasualObserver
      Good running 1984 GT-1800 with solid, quiet and smooth 48 inch deck. Original condition. Hydraulic lift works correctly. Great tractor. Pick up in Kasson, MN. Cash at pick up.
    • Bean701
      By Bean701
      My 312 I understand is equipped with a fragile Eaton transaxle.  My tractor does NOT have hydro deck lift.  My old GT1800 which I plan to salvage parts from has the more stout 1100 hydro setup with the hydro lift.  Can it be made to work in the smaller 312 tractor with minimal hacking?
      While im here, I’m also wondering if the larger front wheels on my GT will fit on the front axle of the 312 or if I would have to swap the whole axle...
