Bigt31 8 #1 Posted June 4, 2016 Hello,all.Im having a little trouble with the latest 520-H I picked up.After you start the tractor every one of the warning lights on the dash come on.I wouldn't think that it would actually have that many problems,but I suppose it is possible.I just wondered if anybody else has had this problem,and can steer me in the right direction as to where the electrical problem could be.Thanks,and I hope everyone has a good weekend. Share this post Link to post Share on other sites
cleat 8,059 #2 Posted June 4, 2016 The newer 520's turn all the lights on for a few seconds after you turn on the key as a test of the light panel. The older ones had a test switch to manually check them. Share this post Link to post Share on other sites
Bigt31 8 #3 Posted June 4, 2016 Thanks for responding.I should have made it more clear.The lights come on after starting the tractor,and never go back off. Share this post Link to post Share on other sites
cleat 8,059 #4 Posted June 4, 2016 Which type of module do you have, do you have the test switch ? The module may be bad. I have 2 of the newer style ones here if you need one. Share this post Link to post Share on other sites
Bigt31 8 #5 Posted June 4, 2016 It's the newer style.No test switch.Ill try to check it out tomorrow with an ohmeter,and let you know.Thanks again. Share this post Link to post Share on other sites
