rexman72 210 #1 Posted June 3, 2016 I am in the process of restoring a homemade loader for my D200 and wondering what GPM pumps you use and the size of the pulley you use on your loaders and wheres the best place to buy them? 1 Share this post Link to post Share on other sites
WNYPCRepair 1,924 #2 Posted June 3, 2016 Northern Tool has a few. I built my own loader with this pump and a 6" pulley, but it might be just a bit too powerful, the bucket moves a little faster than I would like. http://www.northerntool.com/shop/tools/product_200329712_200329712 3 Share this post Link to post Share on other sites
Racinbob 12,765 #3 Posted June 3, 2016 and Surplus Center is another good one. http://www.surpluscenter.com/ 2 Share this post Link to post Share on other sites
WNYPCRepair 1,924 #4 Posted June 3, 2016 1 hour ago, Racinbob said: and Surplus Center is another good one. http://www.surpluscenter.com/ I bought my cylinders there Share this post Link to post Share on other sites
rexman72 210 #5 Posted June 3, 2016 So a 4 gpm would work? 1 Share this post Link to post Share on other sites
squonk 45,520 #6 Posted June 3, 2016 I run a .5 cu in 5GPM pump on my homemade Power King loader. You have to match the pump output with the cylinder size. loader boom length, and engine RPM. If you have a hydraulic specialty shop near you talk to them. 4 Share this post Link to post Share on other sites
rexman72 210 #7 Posted June 14, 2016 Do any of you guys have the aluminum or cast iron pumps?when looking at the pumps i see alot of aluminum Share this post Link to post Share on other sites
WNYPCRepair 1,924 #8 Posted June 14, 2016 2 hours ago, rexman72 said: Do any of you guys have the aluminum or cast iron pumps?when looking at the pumps i see alot of aluminum The one at Northern Tool I posted is cast iron Share this post Link to post Share on other sites
rexman72 210 #9 Posted June 14, 2016 ok cool I did see that one Share this post Link to post Share on other sites
wallfish 19,302 #10 Posted June 15, 2016 On 6/3/2016 at 10:21 AM, WNYPCRepair said: http://www.northerntool.com/shop/tools/product_200329712_200329712 Used that same pump for a backhoe too. You can always adjust the flow by changing pulley sizes. I went 1:1 ratio for my setup but if you find it going too fast, you can go with a larger pulley on the pump to slow the rpm. That's the same pump PF Engineering recommends for their loaders too. Share this post Link to post Share on other sites
rexman72 210 #11 Posted June 15, 2016 thats good to know.I was thinking about going with a 4 to 5 inch pulley. Share this post Link to post Share on other sites
WNYPCRepair 1,924 #12 Posted June 15, 2016 10 minutes ago, rexman72 said: thats good to know.I was thinking about going with a 4 to 5 inch pulley. I used a 6". I don't think I can fit a larger diameter pulley without some modification Share this post Link to post Share on other sites
Pullstart 68,882 #13 Posted June 15, 2016 (edited) I don't have a loader, but for my plow trucks I've got a few belt driven plow pumps by fisher that I would imagine could do the trick if they fit in your space allowed. They have a reservoir large enough for the plow cylinder to raise and lower, so if you're using a dual acting cylinder that fills one side as it empties the other, I'd imagine the self contained reservoir would work just fine. I use these pumps along with northern tool spool valves http://www.northerntool.com/shop/tools/product_8516_8516 to run my front plow raise/lower/float, front plow turn and rear plow up/down (pressure both ways) powered by the truck engine without any problems. The fisher pumps can be had on ebay from time to time, there's one now for $78 or best offer including shipping... Edited June 15, 2016 by pullstart specifying truck use... Share this post Link to post Share on other sites
rexman72 210 #14 Posted June 16, 2016 any ideas on how to mount the pump to the front of my D200? Share this post Link to post Share on other sites
WNYPCRepair 1,924 #15 Posted June 16, 2016 2 hours ago, rexman72 said: any ideas on how to mount the pump to the front of my D200? I don't know anything about the D series. Do they have a front PTO? And a front tachomatic? If so, maybe the XI type loader mount might work. A bit of fabrication, but not extremely difficult Share this post Link to post Share on other sites
rexman72 210 #16 Posted June 16, 2016 yes they have a front pto and front tachomatic.I will have to look at an XI loader Share this post Link to post Share on other sites
82Caddy 851 #17 Posted June 16, 2016 Random google photos for you... 2 Share this post Link to post Share on other sites
rexman72 210 #18 Posted June 17, 2016 those pics look like they attach to where my mowing deck pulleys go Share this post Link to post Share on other sites
82Caddy 851 #19 Posted June 17, 2016 It attaches in front of the attach-a-matric bracket. There are two holes the ark loader pump bracket bolts to. Same place the front lower pto guard thing is between the frame rails. There's lots more pictures out there if you look for them. Share this post Link to post Share on other sites
WNYPCRepair 1,924 #20 Posted June 17, 2016 5 hours ago, rexman72 said: yes they have a front pto and front tachomatic.I will have to look at an XI loader Looking at those pics, it looks a bit different than the XI. The thread below shows the XI mount a member here made. I kind of copied it, I bought an extra mule drive and modified it for mine. Share this post Link to post Share on other sites
elliot ness 1,916 #21 Posted June 18, 2016 I buy most my hydraulic pumps and controls and fittings from Bailey hydraulic. Great people that can help you figure out what you might need. and can make you anything hydraulic. all their items are prices below most other places and fast delivery. I have built 6 loaders over the past 15yrs. and always try to use them. Share this post Link to post Share on other sites
rexman72 210 #22 Posted June 18, 2016 I will check bailey out Share this post Link to post Share on other sites
squonk 45,520 #23 Posted June 19, 2016 You will want everything matched up so the loader will not operate too fast and be uncontrollable Share this post Link to post Share on other sites
rexman72 210 #24 Posted June 23, 2016 For you guys with loaders how big is your hydraulic line going to the supply side of the pump and how big is the outlet side? Share this post Link to post Share on other sites
WNYPCRepair 1,924 #25 Posted June 23, 2016 37 minutes ago, rexman72 said: For you guys with loaders how big is your hydraulic line going to the supply side of the pump and how big is the outlet side? Post # 138 the pressure line from the pump is 3/8" ID hose and the suction hose from the res to the pump is 3/4" ID. Share this post Link to post Share on other sites
