buffaloman 295 #1 Posted June 2, 2016 my father in law has i think a b100 hydro ,and the motion lever like to just flop forward and take off. is there something that needs tightening or is that plastic looking piece in there wore out and needs replacing ? Share this post Link to post Share on other sites
953 nut 68,773 #2 Posted June 3, 2016 This manual should help you out. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,478 #3 Posted June 3, 2016 Part 2 of this operator manual has what you need Garry 1 Share this post Link to post Share on other sites
buffaloman 295 #4 Posted June 3, 2016 ok so it looks like loosing a lock nut and then turning that collar to tighten it back up Share this post Link to post Share on other sites
rmaynard 17,548 #5 Posted June 3, 2016 And use no lube on it. 1 Share this post Link to post Share on other sites
daveoman1966 3,884 #6 Posted June 3, 2016 (edited) If adjusting the tension on that friction collar and nut doesn't solve the problem, have a look at the left side of the hoodstand for a fairly common issue. If this lock-down tab is broken, the shift lever will slop around almost by itself. Edited June 3, 2016 by daveoman1966 2 Share this post Link to post Share on other sites
buffaloman 295 #7 Posted June 4, 2016 On 6/2/2016 at 11:47 PM, daveoman1966 said: If adjusting the tension on that friction collar and nut doesn't solve the problem, have a look at the left side of the hoodstand for a fairly common issue. If this lock-down tab is broken, the shift lever will slop around almost by itself. daveoman that is exactly what it was! thanks for the tip , you got any tips for fixing it ? 1 Share this post Link to post Share on other sites
953 nut 68,773 #8 Posted June 4, 2016 Send @daveoman1966, I'll bet he can hook you up with one. Share this post Link to post Share on other sites
