jimmybrad 0 #1 Posted June 1, 2016 Hello. I have a 312-8 speed wheel horse. My sister was mowing today, turned the mower off while blades where still engaged and now it will not turnover. It just makes a clicking sound. Would there be a safety switch that might be disengaged? Does not appear to be a battery issue. Headlights still come on. Share this post Link to post Share on other sites
953 nut 69,563 #2 Posted June 1, 2016 Your PTO needs to be disengaged and clutch depressed to start. I presume you have done this since it "clicks". My guess would be that the problem is a dirty battery cable ends, clean and tighten all connections. Share this post Link to post Share on other sites
slammer302 2,157 #3 Posted June 1, 2016 Sometimes wiggle the deck engaging lever can help. I've had few that I had to wiggle the PTO lever and and press the clutch pedal a few times to get it to start. Share this post Link to post Share on other sites
