doc724 925 #1 Posted May 30, 2016 The muffler in my 1998 314-8 with a Kohler Command Pro has bit the dust. Noticed a 3/4 inch crack at the interface between the flange (where it bolts to the engine) and the pipe. Was planning remove the muffler and get it welded. Cut the grass one last time and about 10 minutes into it, it was apparent that the crack had opened. Welding may still be a possibility-but not easy-pipe is thin wall. So I am shopping for a new muffler and expect it will be pricey. However, Toro does not sell the muffler, only Kohler. Which brings me to the real problem, The engine info tag on the blower housing is not readable-at all. If anyone has one of these 314-8, I need the engine model #, spec# and maybe serial number. Alternatively, if you know where I can find one of these mufflers, that will be helpful. Heading off to prowl ebay now Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,852 #2 Posted May 30, 2016 For tractor model number 73448 Engine CH14-1838 Muffler is shown on the Engine Assembly page https://www.partstree.com/parts/search/models/?searchTerm=73448 What we have in the library http://www.wheelhorseforum.com/search/?q=73448&type=downloads_file Garry Share this post Link to post Share on other sites
doc724 925 #3 Posted May 30, 2016 Garry, thx I must be getting blind. I looked thru my manuals at least 3 times and skipped over the "engine assembly page". I zeroed in on "exhaust" which only showed the studs!. At least now I have the engine model # Share this post Link to post Share on other sites
