welderman85 53 #1 Posted May 29, 2016 Hello all I just picked up a 211-5 and would like to try and get it running. The wiring is a mess and all the safety switchs are gone. The clutch,seat and PTO switches are gone. How can I bypass this mess to just get it running and see what I dealing with. I decide whether to redo or part out. Thank you Share this post Link to post Share on other sites
953 nut 63,075 #2 Posted May 29, 2016 If it is a magneto ignition system there should be a wire coming out from behind the flywheel cover that shorts out the magneto to shut down the engine. It should be routed to the ignition switch and seat safety switch. If you disconnect it at the engine your spark may return. 2 Share this post Link to post Share on other sites
