murph 5 #1 Posted May 22, 2016 starting hard,runs ok at low throttle but high when mowing starts backfiring,also when bumpy mowing.I did replace pump about 2 years ago,This would be my first carb rebuild if that is needed.Anyone know of a good kit with entry level instructions.KOHLER Magnum 14 / model m148 / spec 601559 / sec 2228110723.Thanks, Gavin Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,975 #2 Posted May 22, 2016 Here is the Kohler service manual Tried to determine what kit you need but didn't have any luck. The online parts lists don't seem to have it either https://www.partstree.com/parts/kohler-engines/engines-horizontal/m14-601559-kohler-m14-engine-magnum-wheel-horse-14hp-10-5kw-specs-601500-601557/ Garry ADDING The on-line list shows a replacement carb kit 47 853 29-S which is the complete carb. If you hover over the note it shows a carb number 47 053 96. If you go to pages 3.10 and 3.11 in the carb manual they list the parts for that carb including a kit. Perhaps that is the one you need. I don't know if the original carb and the replacement are the same. A Napa catalog shows the carb kit as 25 757 11-S which matches the info in the carb reference manual. More options https://www.rcpw.com/search/?quest=25+757+11 Garry Share this post Link to post Share on other sites
murph 5 #3 Posted May 22, 2016 THANKS GARRY.I will order that kit from napa,any advice on carb set up? Screw adjustment . Share this post Link to post Share on other sites
953 nut 63,904 #4 Posted May 22, 2016 Take a look at page 6.4. Kohler K-Series SM TP-2379 LR.pdf Share this post Link to post Share on other sites
