mabsoon 60 #1 Posted May 21, 2016 I have a 520H '91 and have some belts I am not sure the usage of. A B128 Gate belt which I am assuming is the deck belts. An A100 Gare belt which I am assuming is the snow thrower belt. apreciate any help in these. just ordered the 110265 for the tiller and going to look through the box for the idler spring. I pulled the tiller mount bracket off the C160 so at least I have the axle bracket that goes with the tiller Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,764 #2 Posted May 21, 2016 You need to measure the lengths of the belts. Some A100's are 1/2" x 100" and others are 1/2" x 102" Some B128's are 5/8" x 128" and others are 5/8" x 131" Garry Share this post Link to post Share on other sites
mabsoon 60 #3 Posted May 22, 2016 Ok, thank, but what attachments are they used with? my 520H came with a 60" mower deck and a snow blower so I assume that's what they go to... Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,764 #4 Posted May 22, 2016 The 1991 model C5-60SC03 60" SD deck uses these belts Drive belt 113072 (1/2" x 103")Spindle belt 112449 (5/8" x 131.25") Garry Adding If you go to Gates the belts you have are what they list as replacements for this application. Share this post Link to post Share on other sites
mabsoon 60 #5 Posted May 22, 2016 Ah, didn't think about the drive belt for the deck. I knew the A-100 seemed too long for the snow thrower. Thanks very much guys. Share this post Link to post Share on other sites
