semperfi8185 56 #1 Posted May 16, 2016 Started up the 73 12 Automatic yesterday to get my mow on and noticed some black smoke when starting the engine and gas dripping from the air cleaner right befor shutting the engine off. Do I rebuild or replace a 43 year old carb? Thanks Greg Share this post Link to post Share on other sites
953 nut 63,100 #2 Posted May 16, 2016 Kits on are about $10 and probably a new needle and seat is all you need. Check the throttle shaft to see how much play it has too. Share this post Link to post Share on other sites
C-101plowerpower 1,606 #3 Posted May 16, 2016 i'd give it a good clean at first 1 Share this post Link to post Share on other sites
Fun Engineer 860 #4 Posted May 16, 2016 Yes, try giving it a good soaking and cleaning first. Share this post Link to post Share on other sites
semperfi8185 56 #5 Posted May 16, 2016 Based on the expert responses to my post I will give it a good cleaning befor buying a replacement. Will let you know how it goes. Greg 1 Share this post Link to post Share on other sites
82Caddy 851 #6 Posted May 16, 2016 I ended up having to replace the one I had on a k341 due to worn throttle shaft. I tried cleaning/new gasket kit and it still leaked. Replacement was an ebay special and haven't had an issue since. Share this post Link to post Share on other sites
