BMW1 44 #1 Posted May 13, 2016 Approximately how much does a Wheel Horse D180 WITH a loader weigh and about how long is it with the loader as well? I am wondering how big of trailer I will need to haul this home. Thanks. No pictures yet. Share this post Link to post Share on other sites
stevebo-(Moderator) 8,604 #2 Posted May 13, 2016 I hauled one home in a snowstorm in upstate NY on a 5x8' tsc trailer. I would not suggest doing it but I was able to. Had to back in and put loader arms over the back gate. 3 Share this post Link to post Share on other sites
82Caddy 851 #3 Posted May 13, 2016 That's on a 16 ft car trailer 6 Share this post Link to post Share on other sites
KC9KAS 4,746 #4 Posted May 13, 2016 I would guess a trailer of at least 4' X 8' with a load rating of at least 1500#. 3 Share this post Link to post Share on other sites
953 nut 64,213 #5 Posted May 13, 2016 Check the laws in your state, some states don't allow any part of the load to protrude beyond the trailer. My GT-14 with loader, weights and loaded tires is 1,300 pounds; the "D" will be a bit more. If you are renting a trailed a tandem axle trailer will work better and help keep the load off the tow vehicle. 1 Share this post Link to post Share on other sites
BMW1 44 #6 Posted May 13, 2016 Thanks everyone for the answers and suggestions. Appreciate the help. Share this post Link to post Share on other sites
82Caddy 851 #7 Posted May 13, 2016 If you need an exact estimate on length, I can get you one this evening. 3 Share this post Link to post Share on other sites
BMW1 44 #8 Posted May 13, 2016 Actually, if you don't mind, I would appreciate that - thanks! Share this post Link to post Share on other sites
82Caddy 851 #9 Posted May 14, 2016 Missed your response until now. I'll get those measurements once I get home from date night with my wife. Share this post Link to post Share on other sites
brandonozz 168 #10 Posted May 15, 2016 BMW1 - I had the same problem when I purchased my D and loader - how to haul it around? From the back of the tires to the front of the loader when resting on the ground is about 10'. If you have a weight box on the back (or in my case counter weight steel skid I pick up with the 3 PT) you might want to allow for more length. As far as weight the tractors dry weight I believe is like 1025 plus the FEL is probably 300 pounds or so. If you add 300 pounds out back and some wheel weight you should probably plan on 1800 pounds or so. If purchasing a trailer, I'd make it at least 12' and rated at 2K myself. 1 Share this post Link to post Share on other sites
