Philip Parry-jones 26 #1 Posted May 11, 2016 After watching a church groundsman mowing around the tombstones with a Stiga mower and talking to him it looked as if I NEEDED a Stiga mower.After bidding for a few on ebay I finally got one.Yes it did get into corners but even though it was meant to be 13.5 HP it would not cut long grass like my C101 which has a 10HP Kohler,it was unstable on slopes and the wheels spun on inclines.Luckily my C101 has not been sold so I am now giving it a bit of care before putting it back into use.I really need a set of new blades but as I have welded and painted the deck I do not have a part number for them.The deck is a 36" tachamatic rear discharge type and the blades are two at 12" long and one at 14" long,I have not been able to find the number in the manuals section,does anyone know which blades I need?.And the Stiga? sold on ebay and only lost £10,an expensive error,learn by my mistake,red mowers NOT yellow!. 2 Share this post Link to post Share on other sites
JC 1965 1,532 #2 Posted May 11, 2016 I think the part number is 8969. I believe Toro still sells them. I see this is your first post so 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,438 #3 Posted May 11, 2016 8969 3-blade set is correct if the blades require a 5/8" x 3/4" double-D center hole to mount them. Has to be perhaps the only set with this type of center hole that are still available from Toro. They eventually went to a blade with a 3/4" round hole for later decks. Garry 2 Share this post Link to post Share on other sites
Philip Parry-jones 26 #4 Posted May 11, 2016 Many thanks,have had the blades off to check and they have a 3/4" round hole,I have sharpened what was left of them an put them back,I am not a new member,it`s just that I have changed my internet provider,don`t forget,red not yellow,Cheers! Phil. 11 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,438 #5 Posted May 11, 2016 Not knowing the deck model number it is a guess at which blade to use looking at the parts lists. 1979 rear discharge deck 95-36MR01 uses 107982 blade set (Approx $80.38) 1979 side discharge deck 95-36MS01 uses 107983 blade set (Approx $72.92) When you get to 1985 rear discharge deck 05-36MR03 uses 107983 blade set. and there are more. The last rear discharge deck model 78305 in 2006 used these. The last 36" side discharge deck in 1984 model 05-36MS02 also used these. Perhaps someone can explain the difference. All have the 3/4" round hole. Aftermarket suppliers replace both blade sets with the same blades. Original part numbers 107435 (L&R) and 107436 (Center) were replaced by the 107982 3-blade set Original part numbers 107437 (L&R) and 107438 (Center) were replaced by the 107983 3-blade set Garry Share this post Link to post Share on other sites
TDF5G 2,073 #6 Posted May 11, 2016 (edited) Is it correct that the side discharge decks have a higher lift blade? Which obviously would be a different part # than the rear discharge blade. And those are great pics! Edited May 11, 2016 by TDF5G Share this post Link to post Share on other sites
Philip Parry-jones 26 #7 Posted May 11, 2016 Feel ashamed at being seduced by the swedish stiga! the wheel horse has been a loyal friend for many years.Moving trailers,pulling boats up the slipway and of course cutting the grass.She seems to have forgiven me. 5 Share this post Link to post Share on other sites
TDF5G 2,073 #8 Posted May 11, 2016 The old girls can be very forgiving! Share this post Link to post Share on other sites
gregg'shorses 77 #9 Posted May 11, 2016 Treat her to an oil change and a fresh air filter. Share this post Link to post Share on other sites
Philip Parry-jones 26 #10 Posted May 12, 2016 Promised her some new tyres!. Share this post Link to post Share on other sites
Retired Wrencher 5,764 #11 Posted May 12, 2016 Philip Parry- jones. They where made to last a life time. If you do the P.M.`s I always said if take care of them they will take care of you. 3 Share this post Link to post Share on other sites
