mancanic2 4 #1 Posted May 10, 2016 to whom it matters, I have a 91 520h 20 hp onan with a 60" deck. while mowing vacuum drops to 5"mg, engine bogs unless I move a a snails pace. high grass fresh doesn't matter. any help is greatly accepted. Dale 1 Share this post Link to post Share on other sites
russellmc301 600 #2 Posted May 10, 2016 check your spark plug it may have something to do with it. the pros will be here to help in a bit Share this post Link to post Share on other sites
boomers_influence 106 #3 Posted May 10, 2016 dale what is high grass fresh? bogging could be lack of power, due to lack of fuel, or one of the cylinders going south. do a compression and leak down test. thank you. boomer ( the used onan engine parts guy, also NOS and new ) Share this post Link to post Share on other sites
mancanic2 4 #4 Posted May 10, 2016 high grass/ fresh cut grass Share this post Link to post Share on other sites
skrusins 128 #5 Posted May 10, 2016 Are you cutting one third or more? That means if your lawn is 3in tall your suppose to cut only 1 in. Share this post Link to post Share on other sites
mancanic2 4 #6 Posted May 11, 2016 did not know that, but do have deck raised, and scalp wheels at highest posistion Share this post Link to post Share on other sites
ericj 1,579 #7 Posted May 11, 2016 a good running onan shouldn't bog down in 3" high grass. like said above check compression on both cylinders, sounds like it might be heading south, I just reread your post, with a 60" deck in real thick high grass it may bog some but should go through, maybe a video of it in action, good luck eric j Share this post Link to post Share on other sites
mancanic2 4 #8 Posted May 13, 2016 Grass was close to 6" or 7". Dry, Engine runs 12' of vac. until pto is engaged, vac drops uses alot of fuel but runs well. both spark plugs are white at gap, might be running lean? pics and vid tmrw Share this post Link to post Share on other sites
skrusins 128 #9 Posted May 13, 2016 Once you get cut down at a snails pace. You may have to cut more often, especially during early spring. Share this post Link to post Share on other sites
mancanic2 4 #10 Posted May 14, 2016 does this even on well mowed lawns, blades spin up after a moment.. kinda like heliocopter blades or the sound of them.. just lack of full engine power Share this post Link to post Share on other sites
mancanic2 4 #11 Posted May 14, 2016 problem solved. had drive belt way to tight and grass was just to high for speeds I was mowing at.. all insights taken thank you! 1 Share this post Link to post Share on other sites
