fishingstararlake 1 #1 Posted May 10, 2016 Hi guys, My wheel horse has a 20hp onan. The starter bendex doesn't engage all the time. I have taken it out and cleaned it but that doesn't help. I jumped it out of the tractor the drive would pop out and was very hard to hold on to. I cleaned the contacts and replaced the fuse. How do I test to find out if it is in the drive or power to it? Thank you Dan Share this post Link to post Share on other sites
cleat 8,110 #2 Posted May 10, 2016 I had one that would do that. This one had the start solenoid removed (not the starter solenoid, but the one inline to the starter). I wired in a lighting solenoid and it now works properly. It is the one called "auxiliary solenoid" in the attached wire diagram. Wheel horse 520H wire diagram.pdf Share this post Link to post Share on other sites
fishingstararlake 1 #3 Posted May 11, 2016 so you think it could be low on power? how lose should the solenoid gear be? I can wiggle mine side to side. Share this post Link to post Share on other sites
