Lyman1234 23 #1 Posted May 9, 2016 Just finished the restoration of this cart. I picked it up from a great guy, and the shape was good, just needed some TLC. 14 Share this post Link to post Share on other sites
Aldon 4,828 #2 Posted May 10, 2016 Did you use Bedliner and if so, spray or roll on? Share this post Link to post Share on other sites
Lyman1234 23 #3 Posted May 10, 2016 Hi, I used Rust-Oleum Truck Bed Coating not bedliner which I found to be different I believe in consistency. 2 Share this post Link to post Share on other sites
AlwaysLookin80 1,308 #4 Posted May 10, 2016 10 hours ago, Lyman1234 said: Hi, I used Rust-Oleum Truck Bed Coating not bedliner which I found to be different I believe in consistency. Did you have to get down to the bare metal to use this spray? Share this post Link to post Share on other sites
JPWH 6,358 #5 Posted May 10, 2016 Very nice restoration. Too pretty to use now. Share this post Link to post Share on other sites
Lyman1234 23 #6 Posted May 10, 2016 No, that's why I used the bedliner, it will be used all my stuff is restored and run pretty hard and restored again. 3 Share this post Link to post Share on other sites
JPWH 6,358 #7 Posted May 10, 2016 19 minutes ago, Lyman1234 said: No, that's why I used the bedliner, it will be used all my stuff is restored and run pretty hard and restored again. I feel the same way. I have my horses and equipment to use. Share this post Link to post Share on other sites
Lyman1234 23 #8 Posted May 10, 2016 No you do not, however I used filler primer on the whole surface and sanded the entire cart. I did take a grinder to some of the surface rust areas only as this is quicker. Agree with using them, they don't like to stand in the stables to long LOL Share this post Link to post Share on other sites
