ba2988 28 #1 Posted May 7, 2016 Just wanted to say thanks for this site and especially to SOI and rmaynard - even though I didn't have to ask for them to assist directly, reading through old posts walked me through everything I needed to do. Two weekends ago I went to put the mowing deck on, turned the key and nothing. No dash lights, no clicks or other noises, nada. And it had just ran fine when I moved it into the garage. Did a few quick checks on the battery (ok), ground wire (ok), key switch (nothing), and fuses with the multi-meter (which showed no power at the fuses with the key turned on) then figured I was going to have to dig deeper. Fuse box and wires going into it looked ok at first - later on when I took it off there was some melting in one of the wire locations. A check of the 9 pin connector showed what I think was the main issue, 2 of the wires were burnt out in the sockets. So I ordered a new connector from rmaynard (great transaction) bought fuses and went to work - a few hours later I had things connected back up, and it fired right up. Nothing like that feeling! Thanks again Red Square!! Brice 9 Share this post Link to post Share on other sites
Sparky-(Admin) 24,646 #2 Posted May 7, 2016 Awesome...that's what this site is all about! And those two members you mentioned are first class members in my book! Mike..... 4 Share this post Link to post Share on other sites
Tankman 3,528 #3 Posted May 7, 2016 10 minutes ago, Sparky said: Awesome...that's what this site is all about! And those two members you mentioned are first class members in my book! Mike..... Yes they are! 2 Share this post Link to post Share on other sites
TDF5G 2,073 #4 Posted May 9, 2016 On 5/7/2016 at 7:23 PM, Tankman said: Yes they are! I'll agree with that. Best forum on the web! Share this post Link to post Share on other sites
