welderman85 53 #1 Posted May 6, 2016 I have recently pick up a c-145 that was supposed to run great. Well not so much.So far I have pulled the head cleaned the tons of carbon buildup. And cleaned the carb. Now it starts alittle better but it won't run with out the choke on. It will start and idle but once you go to turn the choke off it will shoot a flame out of the exhaust and die. Share this post Link to post Share on other sites
Ed Kennell 44,619 #2 Posted May 6, 2016 I would do the standard tune up....replace the plug, points, and condenser. If it till requires choking to run, look for air leaking in around a worn throttle shaft or bad gasket on the carb mounting flange. 1 Share this post Link to post Share on other sites
welderman85 53 #3 Posted May 7, 2016 Ok thank you. I have a new condenser,points and carb heading my way I hope this gets it straightened out Share this post Link to post Share on other sites
