gamaemry305 0 #1 Posted December 14, 2008 Is it common for short frame tractors to have this frame problem? I have been chasing down an excessive PTO belt wear problem and found this when I started cleaning up the PTO pullies. Right Side Left Side, Small plate welded on inside Share this post Link to post Share on other sites
BPjunk 184 #2 Posted December 14, 2008 My guess is that a really big guy has been stepping off the right side using the foot rest. With this design of the 3/4 inch steel rod being welded to a cut out in the frame this could happen ..... but I have not seen this very offten. Wild Bill in Richmond, Va. Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #3 Posted December 14, 2008 That condition is indicative of a tractor that suffered repeated hard landings on the front wheels. (too many wheelies ) The short-frame tractors are more apt to lift the front end when starting off or pulling. If filled tires or wheel weights are used, it's recommended to install a front counterweight of some sort. (or wheelie bars ) Share this post Link to post Share on other sites
