gwest_ca-(File Mod) 11,712 #2 Posted April 24, 2016 The 1963 model 753 used a Kohler K161S-28626E Garry Share this post Link to post Share on other sites
buffaloman 295 #3 Posted April 24, 2016 the wheel horse is a 702 ,I was wondering if these numbers confirm the correct motor? and if these numbers are what I need to identify what fuel pump I need ? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,712 #4 Posted April 24, 2016 Here is a parts list. The K161S-28622E listed for the 702 does not show a fuel pump. Lists a cover and gasket for the pump location. The K161S-28626E lists a B-231390-S pump that is no longer available from Kohler. Garry Share this post Link to post Share on other sites
buffaloman 295 #5 Posted April 24, 2016 Will the one on the left work? Share this post Link to post Share on other sites
pfrederi 18,952 #6 Posted April 24, 2016 (edited) The one on the right would work It uses the change in crankcase pressure (pulse) to move the gas. I am not sure about the left i thought (dangerous) that the small block Kohlers (7-8 hp) had an offset bend in the actuating lever. Edit: The one on the left is for 10hp and up. will not work on your motor. Edited April 24, 2016 by pfrederi Share this post Link to post Share on other sites
buffaloman 295 #7 Posted April 24, 2016 The one on the right is what came off the tractor ,is it repairable? Share this post Link to post Share on other sites
pfrederi 18,952 #8 Posted April 24, 2016 Probably a bad diaphragm. Contact Buckrancher on here Share this post Link to post Share on other sites
rmaynard 16,561 #9 Posted April 24, 2016 24 minutes ago, buffaloman said: The one on the right is what came off the tractor ,is it repairable? Let me know if you have any problems getting that pump to work. I may have the parts you need to fix it. I am located not far from you in Westminster, MD. 2 Share this post Link to post Share on other sites
buffaloman 295 #10 Posted April 24, 2016 (edited) Thanks! Rmaynard ,ill keep that in mind.im asumong the one on the right is missing that arm??? Edited April 24, 2016 by buffaloman Share this post Link to post Share on other sites
rmaynard 16,561 #11 Posted April 24, 2016 It's not missing an arm, it never had one. It is a pulse pump and uses crankcase pressure changes to move the diaphragm up and down inside the pump. 2 Share this post Link to post Share on other sites
