ametsman5 2 #1 Posted April 16, 2016 I am in need of a pulley for a 606 tractor. It is the one off the transmission. The part number is 1611. Any help would be greatly appreciated. Share this post Link to post Share on other sites
daveoman1966 3,882 #2 Posted April 16, 2016 Can you tell me the pulley dimensions? OD...? ID...? (the dia of the hole...or the dia of the shaft it fit onto.? Belt width...? 1/2 or 5/8" I have many keyed pulleys here but I never marked them for part #s. MAYBE I have what you need? Share this post Link to post Share on other sites
Retired Wrencher 6,468 #3 Posted April 16, 2016 ametsman5 look in the manuals section here I think it would be there if not I think I have the #. should find one e-bay. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,008 #4 Posted April 16, 2016 #1611 driven transmission pulley used 1958-1969 4.000" OD x .750" shaft for 1/2" belt 3/16"x3/4" (.740" long) #9 Woodruff key Set screw 1/4"-20x5/16" Garry 1 Share this post Link to post Share on other sites
daveoman1966 3,882 #5 Posted April 16, 2016 I have that pulley on Ebay. Look at item # 131777881327. It is marked as pulley # 7232 and another # on it is 5425, but it is the EXACT DIMENSIONS needed... 4" x 3/4" for a 1/2 " belt. I thought it was for a 5/8 belt but I am wrong. It is for the 1/2' BELT. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,008 #6 Posted April 16, 2016 Part #7232 should be the same except has a 5/8" ID for the 6-speed transmissions used in the models 867 and 1067. #5425 when it was a part number had a 3/4" ID. Casting numbers may differ. Garry Share this post Link to post Share on other sites
daveoman1966 3,882 #7 Posted April 16, 2016 (edited) This pulley is stamped with two numbers: 7232 or other number of 5425.. It is 4" dia and has a 3/4" hole for the shaft. It is NOT 5/8" shaft size. The pulley is stamped with two numbers:: 7232 and 5425 as shown in these pics. Edited April 16, 2016 by daveoman1966 Share this post Link to post Share on other sites
ametsman5 2 #8 Posted April 16, 2016 (edited) Looked in the manual it doesn't have shaft size. I will have to measure it tomorrow. Edited April 17, 2016 by ametsman5 Share this post Link to post Share on other sites
daveoman1966 3,882 #9 Posted April 17, 2016 Here is the Ebay listing: Share this post Link to post Share on other sites
daveoman1966 3,882 #10 Posted April 17, 2016 In going thru a box of older pulleys, I found ANOTHER pulley # 7232 also stamped # 5425. It is also NOS. It is 4." DIA x 5/8" bore using a 1/2" width belt....with a keyway slot and SET SCREW. I just listed it on Ebay as item # 131784758044. 1 Share this post Link to post Share on other sites
ametsman5 2 #11 Posted April 18, 2016 It is a 3/4" bore shaft. 2 Share this post Link to post Share on other sites
