BMW1 44 #1 Posted April 16, 2016 Does anyone know where I could get two rims that fit on the 1 inch spindles? Also need the thrust needle bearings and washers for the 1 inch spindle and a source for the 1 inch wheel bearings if rims we find do not have bearings or bearings are bad. We are upgrading the front end of a 1973 18 automatic. We have the HD axle for 1 inch spindles and the 1 inch spindles, but that is it, well sort of. We were told the rims from a D250 would work, but they do not fit on the 1 inch spindles. Looks like they are metric and from what I read, sounds like the D250 was built overseas, so that is my fault for not doing enough research. The HD axle and spindles we bought are from a D200 and I believe these will fit on an 18 automatic. Thanks for any assistance. Share this post Link to post Share on other sites
"D"- Man 827 #2 Posted April 16, 2016 P.M. Sent, Mark. Share this post Link to post Share on other sites
cleat 9,324 #3 Posted April 16, 2016 Would 1" trailer hubs, bearings work ? 1 Share this post Link to post Share on other sites
BMW1 44 #4 Posted April 16, 2016 Very nice collection of Wheel Horse tractors you have!!!!!! I don't know but I will check into that if I can't find any rims. Thank You! Share this post Link to post Share on other sites
82Caddy 851 #5 Posted April 16, 2016 I have a set of 1" bearing wheels as well. Let them go cheap as I'm considering throwing them away to clean up the shop. 1 Share this post Link to post Share on other sites
Marv 996 #6 Posted April 16, 2016 I have two of the rims. I also have two used bearings. bearings are good. You may be interested in taking a look at this. Marvin 1 Share this post Link to post Share on other sites
BMW1 44 #7 Posted April 16, 2016 I found and purchased a set of rims from a member. Thanks for all the offers and ideas. 1 Share this post Link to post Share on other sites
