skrusins 128 #1 Posted April 14, 2016 Must be missing something. Turn key and get nothing. Can jump solenoid fires right up. Only 2 safeties, PTO and clutch pedal. Change solenoid no difference. Check switch when I turn the key to the start position it did get 12V. What else can I check? Thanks in advance. Share this post Link to post Share on other sites
oldredrider 2,553 #2 Posted April 14, 2016 If you have an ammeter on the tractor, check to make sure the wires are connected to it solidly. 2 Share this post Link to post Share on other sites
skrusins 128 #3 Posted April 14, 2016 OK I do that now. Thanks Share this post Link to post Share on other sites
Racinbob 12,706 #4 Posted April 14, 2016 By "jump the solenoid" do you mean bypassing it or sending 12v to the start terminal? Since you replaced it let's assume it's fine. Get the wiring diagram for your year B-80 and, with a voltmeter or test light, take it one step at a time starting at power to the ignition switch, output in the start position, to the first safety switch, output from that switch, the same for the second switch and on to the solenoid terminal. That's a pretty basic system and it's not difficult. Just one step at a time until you find the problem. 2 Share this post Link to post Share on other sites
skrusins 128 #5 Posted April 14, 2016 Paul, The ammeter gauge shows a discharge with the key on. Racinbob, The way I jumped the solenoid is12v to the start terminal. The solenoid I replaced is a 12V auto solenoid which I think is new, but that made no difference. I will do what you stated "one step at a time". I do think it's a safety issue. I have power to four terminals with the key on, and the fifth has 12V in start position. Also I use the tractor plowing snow this winter. I try finding the wiring diagram and go from their. Thanks the both of you. Share this post Link to post Share on other sites
WNYPCRepair 1,924 #6 Posted April 14, 2016 Here are a couple of diagrams, not sure what year yours is 2 Share this post Link to post Share on other sites
skrusins 128 #7 Posted April 14, 2016 Downloaded copies. Thank You 1 Share this post Link to post Share on other sites
skrusins 128 #8 Posted April 16, 2016 With a lot of help We and I found the problem. Not only having one bad solenoid I had two the nice one that I had was bad also. I am making sure both are in the trash and not on the shelf. Once again Thank you 2 Share this post Link to post Share on other sites
