welderman85 53 #1 Posted April 13, 2016 Hi all sorry if I posted this on the wrong spot. I have a pretty decent electro 12 I have been find out what it's rated to pull. I have a home made drag mower that's kinda heavy I would like to pull with this tractor but don't want to harm it Thank you Share this post Link to post Share on other sites
953 nut 65,157 #2 Posted April 13, 2016 6 minutes ago, welderman85 said: don't want to harm it All you can do is give it a try, if it isn't struggling to pull it then there shouldn't be a problem. Check the temperature of the Hydro every few minutes, that would probably be the greatest fear. 2 Share this post Link to post Share on other sites
pfrederi 20,234 #3 Posted April 13, 2016 If the drag mower isn't putting heavy weight on the drawbar then you will spin your wheels before you do any damage to the hydro/transxle. Share this post Link to post Share on other sites
Tankman 3,528 #4 Posted April 13, 2016 Doubt any harm to your Horse pulling a drag mower. I've pulled gang reels and Swisher trail mowers although not with an Electro Horse. Pulled lots more too! Heavy rollers and carts piled high! Any pic's of your home made drag mower? Share this post Link to post Share on other sites
