MambaJack
Where to find new rear tire for my 314-8
MambaJack
Current tire is 22 x 7.5 x 12, anybody know where i can get a somewhat inexpensive replacement?
Thanks,
dave
WHX??
Might want to check sowm of the places listed here
RedRanger
Might be easier and cheaper to replace both with a more available size.
shallowwatersailor
Sometimes Wheel Horse used that size tire (22X7.50-12) so that the owner could use chains in the winter for snow duty due to clearance issues with certain models. If you are not using chains, the 23X8.50-12 will fit. They are more common and usually cheaper.
Tankman
Try Miller Tire. Not the size you're looking for but should work well.
http://www.millertire.com/categories/lawn-garden-tires/23x-8-00-12/
MambaJack
Thanks for the feedback.  This is probably a stupid question, but if i change the size to  23X8.50-12 , probably have to get new on both sides right?
WHX??
Should but wouldn't absolutly have to have to...might sit a little crooked & mow uneven :confusion-shrug:
RedRanger
Well....the new one should be an inch taller and an inch wider than the original.
It would work, but I'd replace both.
If you watch Craig's List, there are almost always used tires on there for cheap in the 23x?-12 sizes.
Edited by RedRanger
