MambaJack 0 #1 Posted April 11, 2016 Current tire is 22 x 7.5 x 12, anybody know where i can get a somewhat inexpensive replacement? Thanks, dave Share this post Link to post Share on other sites
WHX?? 55,132 #2 Posted April 11, 2016 Might want to check sowm of the places listed here Share this post Link to post Share on other sites
RedRanger 1,470 #3 Posted April 11, 2016 Might be easier and cheaper to replace both with a more available size. Share this post Link to post Share on other sites
shallowwatersailor 3,220 #4 Posted April 11, 2016 Sometimes Wheel Horse used that size tire (22X7.50-12) so that the owner could use chains in the winter for snow duty due to clearance issues with certain models. If you are not using chains, the 23X8.50-12 will fit. They are more common and usually cheaper. 1 Share this post Link to post Share on other sites
Tankman 3,528 #5 Posted April 12, 2016 16 hours ago, shallowwatersailor said: Sometimes Wheel Horse used that size tire (22X7.50-12) so that the owner could use chains in the winter for snow duty due to clearance issues with certain models. If you are not using chains, the 23X8.50-12 will fit. They are more common and usually cheaper. Try Miller Tire. Not the size you're looking for but should work well. http://www.millertire.com/categories/lawn-garden-tires/23x-8-00-12/ Share this post Link to post Share on other sites
MambaJack 0 #6 Posted April 12, 2016 Thanks for the feedback. This is probably a stupid question, but if i change the size to 23X8.50-12 , probably have to get new on both sides right? Share this post Link to post Share on other sites
WHX?? 55,132 #7 Posted April 12, 2016 Should but wouldn't absolutly have to have to...might sit a little crooked & mow uneven 1 Share this post Link to post Share on other sites
RedRanger 1,470 #8 Posted April 12, 2016 (edited) Well....the new one should be an inch taller and an inch wider than the original. It would work, but I'd replace both. If you watch Craig's List, there are almost always used tires on there for cheap in the 23x?-12 sizes. Edited April 12, 2016 by RedRanger Share this post Link to post Share on other sites
