daveoman1966 3,881 #1 Posted April 10, 2016 (edited) I have a NOS engine V belt pulley with the Briggs / Stratton logo embossed on it, but not sure what model tractor it is for. I can only read two numbers on it... '077' in one place and '3' sideways next to that. The cast pulley is 4.0" dia and it has a 1.0" bore with keyway slot to fit a crankshaft WITH a woodruff key. It does NOT have a lockdown set screw. This is for a 'B' size belt (5/8). Again.... any HELP out there..... You may contact me via direct email to : daveoman@windstream.net Edited April 10, 2016 by daveoman1966 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,853 #2 Posted April 10, 2016 These pulleys are 4" OD with a 1" ID but don't know the belt widths. 101875 pulley Engine with manual transmission 8hp Kohler & B&S Used with 100425, 106165 transmission pulley. OEM 1972 1973 1974 1975 1976 1978 1979 1982 1983 1986 1987 1988 106814 replaced by 110139 Engine with manual transmission C-111 8-spd, C-161 Twin 8-spd, 1100 Special 8-spd, GT-2500 8-spd, GT-1142 8-spd, GT-1642 8-spd, SB-421 8-spd (What about C-161 Twin Auto?) Used with 7492, 106165 transmission pulley OEM 1978 1979 1980 1981 1982 110139 Replaces 106814 Engine with manual transmission GT-1142 8-spd, GT-1642 Twin 8-spd, GT-1100 8-spd, GT-1600 Twin 8-spd A1-16B801 Used with 7492, 106165 transmission pulley Replacement for 1978 1979 1980 1981 1982 OEM 1983 1984 Garry Share this post Link to post Share on other sites
daveoman1966 3,881 #3 Posted April 10, 2016 (edited) Thanx for tryin', but this Briggs pulley doesn't match to any of your suggestions. It may, in fact, not even be for a Wheelhorse....not sure at all. I state that because this Briggs pulley does NOT have a SET SCREW to lock down onto the woodruff key. It also does NOT have a 4-bolt pattern face to attach a PTO clutch disc as do all of the other Wheelhorse engine pulleys that I've ever seen. Edited April 10, 2016 by daveoman1966 chnage note Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,853 #4 Posted April 11, 2016 I posted those more to see where that size of pulley was used. In the back of my mind I'm thinking possibly B&S supplied an engine with a drive pulley but have never noticed if they did. The earliest use I see for B&S is the 1971 800 Special model 1-0150 which uses a 100975 pulley that I missed but I don't know the OD of that one. Garry Share this post Link to post Share on other sites
cschannuth 3,819 #5 Posted January 23, 2019 (edited) On 4/11/2016 at 3:26 AM, gwest_ca said: I posted those more to see where that size of pulley was used. In the back of my mind I'm thinking possibly B&S supplied an engine with a drive pulley but have never noticed if they did. The earliest use I see for B&S is the 1971 800 Special model 1-0150 which uses a 100975 pulley that I missed but I don't know the OD of that one. Garry Sorry this is so old but can you direct me to the size of the input pulley on my 78C – 161? I also would like to know what size belt it should have. I’m currently running a 5/8 x 84” which seems a little too long. It has the twin Briggs on it. And the pulley down by the transmission looks to be about 6 1/2 inches diameter with about a half inch diameter hub. I’m wondering what pulley that is or at least the actual specs on it. Thanks. And if you don’t wanna waste your time on this or can’t find anything that is no problem at all I totally understand. I did some searching on here and it doesn’t look like my pulleys match up with what’s listed. Edited January 23, 2019 by cschannuth Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,853 #6 Posted January 24, 2019 1978 C-161 Twin with what transmission? Hydro or gear. When you go to the parts list there are 6 engine pulleys because the transmission determines the diameter and the engine the shaft size - 1" or 1-1/8". B&S are 1". There are 3 transmission pulleys listed - 2 for hydro trans and 1 for gear trans. Garry Share this post Link to post Share on other sites
cschannuth 3,819 #7 Posted January 24, 2019 Sorry. It’s the 8 speed. I’m really trying to pin down the belt length and width. Thank you so much for helping me. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,853 #8 Posted January 25, 2019 Tractor drive belt has been added to this page. Click on the picture Garry 1 Share this post Link to post Share on other sites
daveoman1966 3,881 #9 Posted January 25, 2019 Is the BRIGGS pulley you want? CAST....4" OD to fit a 1" shaft. Belt width is 5/8". It is NEW...laying around for years. $40 shippe3d to you in USA. Share this post Link to post Share on other sites
cschannuth 3,819 #10 Posted January 25, 2019 23 minutes ago, daveoman1966 said: Is the BRIGGS pulley you want? CAST....4" OD to fit a 1" shaft. Belt width is 5/8". It is NEW...laying around for years. $40 shippe3d to you in USA. Thanks, but I was looking for the pulley that goes on the shaft to the transmission. Share this post Link to post Share on other sites
