russellmc301 601 #1 Posted April 1, 2016 (edited) i have a blown repco, i was wondering were i could locate a new one. repco fg-4175 Edited April 1, 2016 by russellmc301 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,990 #2 Posted April 2, 2016 Is this a voltage regulator? If so what amperage is the charging system? Garry Share this post Link to post Share on other sites
russellmc301 601 #3 Posted April 2, 2016 (edited) it's a 14 hp 8 speed i'm not sure but i hope someone can tell me. i'll look at the mannal Edited April 2, 2016 by russellmc301 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,990 #4 Posted April 2, 2016 Should be a 15 amp system. Kohler did not supply the regulator with the engine so it should be in the tractor parts list The regulator is item 11-28 and original part number 101450 - very common to Wheel Horse. A Google search for "101450 regulator" will bring up many replacement options. Garry Share this post Link to post Share on other sites
russellmc301 601 #5 Posted April 2, 2016 how about the wiring harness found a used one for 25 it has a broken fin does the fin matter? Share this post Link to post Share on other sites
russellmc301 601 #6 Posted April 3, 2016 where could i get a wiring harness? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,990 #7 Posted April 3, 2016 I don't think you will find a wiring harness unless some one has parted out a tractor. A post in the wanted classifieds here would be the best approach. The plastic terminal holder for the regulator is no longer available from Toro but they are not the only company that used them. You need one that matches the terminal locations. If you have the original the terminals can be removed and replaced. That is what most owners do. That and a bit of wire you could make your own harness. If you can solder the connections to the terminals you would have a harness that would outlast all of us. Is that an option? Garry Share this post Link to post Share on other sites
