buffaloman 295 #1 Posted March 28, 2016 I wanted to order a new set of blades for my 48" deck side discharge. they are 16" long . where is the best place to get them . I know probably the big show .but I cant wait that long. hoping something I can order on -line ? any help would be appreciated . Share this post Link to post Share on other sites
Phatboy 565 #2 Posted March 28, 2016 (edited) I have those Gator Blades on my 48" deck and they are amazing !! I cut my grass the other day looked like green asphalt ,, the best cutting blades i personally have ever used..just google Gator Blades ... Edited March 28, 2016 by Phatboy 1 Share this post Link to post Share on other sites
slammer302 2,156 #3 Posted March 28, 2016 I also like the high lift gator blades my dad has a set on a 36'' RD and you see the grass get pulled up as it cuts. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,920 #4 Posted March 28, 2016 If you need blades with a 5/8" x 3/4" double-D center hole you may be out of luck. We just discovered the normal suppliers are not reproducing them. The later decks use a 3/4" round center hole and the blades are available. There is a spacer/bushing to convert a 5/8" x 3/4" double-D blade to a 3/4" spindle but have no idea how that works. How do you slip a 5/8" wide hole over a 3/4" spindle? Garry Share this post Link to post Share on other sites
cleat 8,374 #5 Posted March 28, 2016 Funny, the double D blade set for 42" is readily available but not for the 48". All of mine are using the round bore later model blades. Share this post Link to post Share on other sites
rexman72 210 #6 Posted March 28, 2016 I just went through this and had to change the spindles to 3/4 inch. Share this post Link to post Share on other sites
Phatboy 565 #7 Posted March 28, 2016 12 hours ago, gwest_ca said: If you need blades with a 5/8" x 3/4" double-D center hole you may be out of luck. We just discovered the normal suppliers are not reproducing them. The later decks use a 3/4" round center hole and the blades are available. There is a spacer/bushing to convert a 5/8" x 3/4" double-D blade to a 3/4" spindle but have no idea how that works. How do you slip a 5/8" wide hole over a 3/4" spindle? Garry It is probly a 3/4" nut with a 5/8" reduced end , on the other end ,, so you screw it on spindle shaft tighten it then screw the blade on it.. Would be my guess.. Share this post Link to post Share on other sites
Kurt-NEPA 756 #8 Posted March 28, 2016 I just ordered a set of 3 of the 3/4" round center Gator blades from Amazon. Best price I could find. Share this post Link to post Share on other sites
buffaloman 295 #9 Posted March 29, 2016 well this is Great news! sarcasm! groan !!!!!! Share this post Link to post Share on other sites
