Mert1975
Help with my deck
Mert1975
Hello I'm new here my name is Marty I would like to start by saying hello! I have a 416-8 with an aging hole infested deck and came across a deck on Craigslist and was unsure if if will fit. It looks the same but looks can be deceiving. The person told me it was off of a 70s D180. I will attach a pic. Any help is appreciated!
daveoman1966
The pic you posted is for a D series tractor, to confirm what the other guy told you.  You only need to swap over the lift hardware from your rotted out deck onto this and it will hang on your 416-8 without complications or modification.  You also should not have to drill holes in this deck to swap over the hardware....it is predrilled
Mert1975
Thank you so much!
daveoman1966
Just be aware that the deck pulleys, spindles, and cutting blades are NOT like those of your rotted deck.  This deck has the much older cast-iron pulleys known as a 'Double-D' style and the 3 blades are also dedicated to the 'Double D' configuration.  The shortfall of the 'Double-D' spindle assembly is that they cannot be greased.
tbarnhart
Just to add to what Dave said about the old spindle assemblies. I have a similar deck under my C-160 that I added a grease fitting on the spindles to provide a bit of lube to the lower needle bearing. The top bearing is a sealed ball bearing, but the bottom is a small needle bearing that runs against the shaft. They were supposedly factory filled with lube and considered maintenance free. When the bottom bearing goes out, it often scars up the spindle shaft and the whole assembly is junk. Also, the double-D blades are getting hard to find. On the other hand, if the spindles and pulleys off of your old deck are still good, you could swap them out into the better deck shell and continue on. That's what I'm planning on doing. If I can make these spindles last long enough to wear out my last set of double-D blades.
Mert1975
Thank you guys I think I'm gonna hold out for one that belongs on my mower. It just sounds like a headache lol.
daveoman1966
I'm surprised.... there really is not much to do to use the D series deck.  You only need to swap over the lift hardware.  It isn't necessary to swap over the spindles, but you can do that if desired.  That D series shell looks like it is in very good shape.
tbarnhart
Yea. Again, I'm with Dave. That deck looks nearly brand new. The shell itself is worth quite a bit just because its not worn or rusty. I would buy that and use it until it needed work and then swap over the spindles and pulleys from your current deck, assuming they are good and the pulleys will come off without ruining them.
pacer
Goodness, YES, dont let that pretty deck get away!! As said, we're talking about 1/2 - 1  hour to gain a really nice deck. Decks are getting harder and harder to find, especially in the condition that one appears to be in!
