fast88pu 3,393 #76 Posted March 17, 2019 Looks factory but better then. 3 Share this post Link to post Share on other sites
fast88pu 3,393 #77 Posted March 21, 2019 Now the fun of waiting for fittings and Electrical parts. 1 Share this post Link to post Share on other sites
fast88pu 3,393 #78 Posted March 23, 2019 I did some plumbing and electrical on her today. Fuel lines almost all in. Hood lights wired up. Tail lights wired up. And I solved that annoying problem that you deal with when removing the instrument pannel to clean or hook up the rock shaft. Now it can fully be removed for access . 2 3 Share this post Link to post Share on other sites
Aldon 4,832 #79 Posted March 23, 2019 Better than new! 1 Share this post Link to post Share on other sites
fast88pu 3,393 #80 Posted March 23, 2019 2 minutes ago, Aldon said: Better than new! Aiming for how it should have came from wheel horse. 1 Share this post Link to post Share on other sites
fast88pu 3,393 #81 Posted March 25, 2019 Secret goodies . Hiding things is fun on these. 1 Share this post Link to post Share on other sites
dclarke 4,270 #82 Posted March 28, 2019 This build is very nicely done, great work Kyle! Share this post Link to post Share on other sites
fast88pu 3,393 #83 Posted March 28, 2019 28 minutes ago, dclarke said: This build is very nicely done, great work Kyle! Thank you Share this post Link to post Share on other sites
Pullstart 70,781 #84 Posted March 28, 2019 On 3/25/2019 at 11:23 AM, fast88pu said: Secret goodies . Hiding things is fun on these. Fuel sending unit / pressure regulator? Share this post Link to post Share on other sites
fast88pu 3,393 #85 Posted March 28, 2019 27 minutes ago, pullstart said: Fuel sending unit / pressure regulator? Pressure regulator Share this post Link to post Share on other sites
fast88pu 3,393 #86 Posted March 31, 2019 Another piece home and ready to be mounted. 1 Share this post Link to post Share on other sites
Lee1977 7,710 #87 Posted March 31, 2019 (edited) On 3/23/2019 at 7:47 PM, fast88pu said: Aiming for how it should have came from wheel horse. If that's what your doing you missed one item you should have fixed. Should have installed a 6472 flange bearing on the upper steering shaft support. Edited March 31, 2019 by Lee1977 Share this post Link to post Share on other sites
fast88pu 3,393 #88 Posted March 31, 2019 3 hours ago, Lee1977 said: If that's what your doing you missed one item you should have fixed. Should have installed a 6472 flange bearing on the upper steering shaft support. I have never had that issue Share this post Link to post Share on other sites
fast88pu 3,393 #89 Posted March 31, 2019 Engine mounted 2 1 Share this post Link to post Share on other sites
Lee1977 7,710 #90 Posted March 31, 2019 1 hour ago, fast88pu said: I have never had that issue That is one of the things that should have been fixed at the factory. Next is the tab on the axle pivot. The third is where the hood stand connects to the gas tank bracket. Poor design on all three areas. None of those areas should have to be fixed as often as they do. Share this post Link to post Share on other sites
fast88pu 3,393 #91 Posted April 5, 2019 Sanding and priming / painting more parts today for the pto. 2 Share this post Link to post Share on other sites
Pullstart 70,781 #92 Posted April 5, 2019 1 hour ago, fast88pu said: Sanding and priming / painting more parts today for the pto. Almost looks dipped in paint! Share this post Link to post Share on other sites
fast88pu 3,393 #93 Posted April 5, 2019 31 minutes ago, pullstart said: Almost looks dipped in paint! Thanks Share this post Link to post Share on other sites
fast88pu 3,393 #94 Posted April 5, 2019 Dash wired up now. 3 Share this post Link to post Share on other sites
fast88pu 3,393 #95 Posted April 6, 2019 Some more photos from today working on it while it was so nice outside. 4 Share this post Link to post Share on other sites
fast88pu 3,393 #96 Posted April 6, 2019 Who has ever seen one of these kits? Winter cable kit 2 Share this post Link to post Share on other sites
ebinmaine 79,741 #97 Posted April 6, 2019 Kyle that is one just plain beautiful tractor 1 Share this post Link to post Share on other sites
rjg854 13,200 #98 Posted April 6, 2019 Gorgeous Wheel Horse tractor. Another great body style. 1 Share this post Link to post Share on other sites
stevebo-(Moderator) 8,741 #99 Posted April 7, 2019 Can you show us pictures of the other side? Share this post Link to post Share on other sites
fast88pu 3,393 #100 Posted April 7, 2019 30 minutes ago, stevebo said: Can you show us pictures of the other side? Share this post Link to post Share on other sites
