Adams94 1,069 #1 Posted March 21, 2016 I am mounting a 48" deck to my 195 for the first time. I robbed the mule drive and belt from my dads 195 that has a 60" for it but is retired. The belt is not long enough to fit. Are there different belts required for a 48" opposed to a 60" on the mule drive? Or am I possible doing something wrong. It has been several years since we mounted the 60" Share this post Link to post Share on other sites
Ed Kennell 42,129 #2 Posted March 21, 2016 http://www.wheelhorseforum.com/files/file/209-chart-belts-blades-lubrication-82-pages-492-0392pdf/ This may help... pages 57-64 Share this post Link to post Share on other sites
Adams94 1,069 #3 Posted March 21, 2016 Thanks I will check that out! Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,512 #4 Posted March 21, 2016 Is the front idler assembly the same for a 48" and a 60" deck? Garry Share this post Link to post Share on other sites
Adams94 1,069 #5 Posted March 21, 2016 Yes it is. The c195 only had one pulley on the front because there was one bolted to the frame Share this post Link to post Share on other sites
Aldon 4,828 #6 Posted March 21, 2016 The manual may not articulate the belt length for 48 with the pulley set up for C195 mule set up. Install the deck and run a non stretching string or cord over the pulleys. Use the cord to make a measurement of length. Do it with the Mule reduced or at the shortest setting. This should give you a close estimate of belt length. If its a bit long, the mule can be extended to fit. 1 Share this post Link to post Share on other sites
