MalMac 1,332 #1 Posted March 19, 2016 Got a friend mounting a 50" grader blade on a newer 520H. He's having trouble with it hitting the front tire's when angled. I have never put a grader blade on a 520 before. All mine been in 300's or C series. Was there a different blade for the 520's. I can not see where there was. That does not mean there wasn't one I just never heard of one. I ask him first if he had the right rear Axel mount on said he did. So I am no help to him. 1 Share this post Link to post Share on other sites
whfan74 2,072 #2 Posted March 19, 2016 He might have a blade from an XI series that look the same but are a bit longer. 2 Share this post Link to post Share on other sites
MalMac 1,332 #3 Posted March 19, 2016 Scott that's a thought, I've never seen one from a Xi. Share this post Link to post Share on other sites
tractorhogg 612 #4 Posted March 19, 2016 8 minutes ago, MalMac said: Scott that's a thought, I've never seen one from a Xi. they look the same but are a bit longer , couldn't help myself 1 Share this post Link to post Share on other sites
AMC RULES 37,204 #5 Posted March 19, 2016 Like maybe, 52". Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,512 #6 Posted March 19, 2016 I cut out the rear bar and drilled new holes centered 5" ahead of the original center. Garry Share this post Link to post Share on other sites
cheesegrader 433 #7 Posted March 20, 2016 The mid mount blade for a 520 is 50" Mine clears the front tires without modification. It is on a swept axle '94. Don't know if the straight axle from '88-89 would make a difference Share this post Link to post Share on other sites
MalMac 1,332 #8 Posted March 20, 2016 I am starting to think somehow when he purchased the blade it had to have the longer XI blade. He says everything is as it should be. So to me is the only exsplonation is to long a blade frame. Share this post Link to post Share on other sites
cleat 7,263 #9 Posted March 20, 2016 I currently have my blade on a 520 with the straight axle. Pivots fine with no interference. Share this post Link to post Share on other sites
whfan74 2,072 #10 Posted March 20, 2016 The blades are the same, it is the framework that is different on the two. The XI is longer due to the longer wheel base. Share this post Link to post Share on other sites
ericj 1,579 #11 Posted March 20, 2016 is it a mid mount grader blade or a front mount dozer blade, the 520-H with the swept front axle requires a plow extension kit to clear the front tires, if it is the mid mount grader blade then it must be the wrong series blade for the tractor eric j Share this post Link to post Share on other sites
Tankman 3,523 #12 Posted March 21, 2016 Definitely the frame, blade length itself shouldn't matter. Blade pivots from the center. Share this post Link to post Share on other sites
