Your Shirtless Neighbor 2 #26 Posted March 16, 2016 Took it to the shop. Tech said it looks fine and it's probably the wiper ring installed wrong. I'll slap it back together and give it another try. Share this post Link to post Share on other sites
squonk 45,364 #27 Posted March 16, 2016 I really don't care. I find it hard to believe that an old Tecky has a bore that's std. and in spec. Good Luck! Share this post Link to post Share on other sites
Your Shirtless Neighbor 2 #28 Posted March 17, 2016 Well, deal with it. This motor has pretty low hours on it. The only reason someone junked it was because the governor blew up and smashed the piston. I got it reassembled and double checked my ring placement, before bolting it all back together. Then "primed" the motor with a drill on the flywheel spinning as fast as it could go. Only a very tiny bit of oil made it to the top of the piston after 2 minutes of turning over at slightly slower than idle speeds. Before, when I took the head off after it was smoking there was a half a shot glass worth of oil in the combustion chamber. Test fire tomorrow. I don't know what most of you guys have a problem with.... I've had Briggs and Honda motors in worse condition with .030 ring gap, bent connecting rods, worn out tappets, leaky head gaskets, all run and not smoke as much as this motor did. Share this post Link to post Share on other sites
Your Shirtless Neighbor 2 #29 Posted March 17, 2016 Fired up, no smoke. Just need to tweak the carb a bit. Maybe I'll just toss a $15 Chinese one on it for the hell of it. Share this post Link to post Share on other sites
Your Shirtless Neighbor 2 #30 Posted March 20, 2016 https://www.youtube.com/watch?v=-4D12AB6y9M Start-to-Finish and all the screw-ups included. Enjoy! Share this post Link to post Share on other sites
pfrederi 19,771 #31 Posted March 20, 2016 1 hour ago, AimlessMoto said: https://www.youtube.com/watch?v=-4D12AB6y9M Start-to-Finish and all the screw-ups included. Enjoy! Says it is private.... Share this post Link to post Share on other sites
Your Shirtless Neighbor 2 #32 Posted March 22, 2016 Fixed! Share this post Link to post Share on other sites
AMC RULES 37,254 #33 Posted March 22, 2016 (edited) https://www.youtube.com/user/AimlessMoto/videos Edited March 22, 2016 by AMC RULES 1 Share this post Link to post Share on other sites
