Pollack Pete 2,273 #1 Posted March 8, 2016 I'm bringing a C-195 back to life after sitting for 5 or 6 years.New points,condenser,and spark plugs.I cleaned out the gas tank,removed the screen on the fuel shut off,replaced all rubber gas lines and installed an in-line filter,removed and cleaned the fuel pump,soaked and rebuilt the carb. Installed the carb and the engine will start and idle,but not a not very smooth idle.The slightest increase of throttle and the engine dies.Will start right back up and have the same wandering idle.If I put my hand over the air intake on the carb and cover all but about a 1/4 inch of the intake,I can very slowly increase the throttle to top speed.I figured I missed some crap in the carb soaking process,so I took it apart and soaked it in the Gunk cleaner again.Blew the carb out and put it back together yesterday.Runs exactly the same.Crazy idle and stalling when given throttle.What am I missing here??? I'm pulling out what little hair I have left.Thanks for any and All info. Share this post Link to post Share on other sites
953 nut 64,206 #2 Posted March 8, 2016 Since you notice improvement when air flow is restricted you have a fuel flow issue,I would start by rechecking the float level, sounds like it may be low. Share this post Link to post Share on other sites
WHX?? 55,141 #3 Posted March 8, 2016 Check the throttle butterfly shaft to see if it is worn. Sounds like it is starving for fuel. Check the main jet for varnish when you have the float bowl off to check the level. 2 Share this post Link to post Share on other sites
cleat 8,743 #4 Posted March 8, 2016 Did you put the filter after the pump ? A lot of pumps do not like restrictions on the inlet side. Share this post Link to post Share on other sites
Daddy Don 912 #5 Posted March 8, 2016 (edited) I had the same problem with my C125. Turned out the point had opened two wide. Reset the point to .16 and that took care of the problem. The book said set at .20 but that was two wide. I even put on a new carb before checking the points. I did not need the new carb but left in on there anyway. My engine is a K301 12hp. Edited March 10, 2016 by Daddy Don 2 Share this post Link to post Share on other sites
Ed Kennell 44,965 #6 Posted March 8, 2016 Sucking air... check around throttle shaft and carb gasket. 2 Share this post Link to post Share on other sites
TDF5G 2,073 #7 Posted March 8, 2016 32 minutes ago, ekennell said: Sucking air... check around throttle shaft and carb gasket. This was my first thought also, if the mixture and idle screws have been set. Share this post Link to post Share on other sites
Pollack Pete 2,273 #8 Posted March 8, 2016 I had checked the throttle shaft for play when I had the carb off.It had little to no play.When I put the carb back on.I used a new mounting gasket.A bought one.Not a homemade one.Today I had it running and sprayed carb cleaner around the intake manifold gaskets.No increase in speed indicating no leaks there.Still shrugging my shoulders. 2 Share this post Link to post Share on other sites
WH nut 553 #9 Posted March 10, 2016 Did you run a wire down the passages to make sure they were clean. Sounds like its running lean. Share this post Link to post Share on other sites
new2horses 287 #10 Posted March 11, 2016 A tip cleaner, if used carefully is a good tool for cleaning those little passages. That would be a OXY-Acetylene cutting torch, tip cleaner. 2 Share this post Link to post Share on other sites
Forest Road 595 #11 Posted March 16, 2016 Have you checked fuel pressure? I had a pump give me a hard time once. Would've sworn it was fine. Finally I used a boat fuel tank and put it on work bench w fuel line going down to carb. She ran perfect on the gravity feed. Replaced fuel line and fuel pump. 2 Share this post Link to post Share on other sites
wildman 205 #12 Posted March 16, 2016 If all else fails soak that carb in some lemon juice i have had real good luck with this stuff Share this post Link to post Share on other sites
rexman72 210 #13 Posted March 16, 2016 I was working on a carb for my d 200 and couldn't figure it out what was going on.I bought a new pump so I didn't think it was a fuel pump issue and low and behold the new fuel pump I put in was junk and it wasn't the carb at all. 1 Share this post Link to post Share on other sites
Ed Kennell 44,965 #14 Posted March 16, 2016 Any progress Pete ? Have you pulled the fuel line off at the carb and cranked it over to verify you have a good spurting fuel supply to the carb ? 1 Share this post Link to post Share on other sites
Pollack Pete 2,273 #15 Posted March 16, 2016 5 hours ago, ekennell said: Any progress Pete ? Have you pulled the fuel line off at the carb and cranked it over to verify you have a good spurting fuel supply to the carb ? No progress at all.I have in fact pulled the fuel line off between the pump and carb.Seems fine???At least there is some fuel being pumped.Also,last time I pulled the carb off,I was careful removing the float bowl.Seemsd to have plenty of gas in the bowl.Something definetitly wrong with fuel delivery to the engine.I'll keep trying.Maybe I WILL get a new fuel pump and try it . 1 Share this post Link to post Share on other sites
rexman72 210 #16 Posted March 16, 2016 28 minutes ago, Pollack Pete said: No progress at all.I have in fact pulled the fuel line off between the pump and carb.Seems fine???At least there is some fuel being pumped.Also,last time I pulled the carb off,I was careful removing the float bowl.Seemsd to have plenty of gas in the bowl.Something definetitly wrong with fuel delivery to the engine.I'll keep trying.Maybe I WILL get a new fuel pump and try it . with mew fuel pumps they usually squirt fuel across the garage 2 Share this post Link to post Share on other sites
