DougL3 63 #1 Posted March 7, 2016 So I have the cable attached to the rocker link under the tractor in the outer most hole. I have 2 links of chain from the rock shaft to the Clevis hitch in the lower of the 2 holes. The lift cable is screwed all the way into the trunion on the bottom of the rock shaft. I can't even ride across my yard with the box scrape attached without dragging at times. I got the entire hitch kit from Wheelhorseman1000 and its on my 94 520H. Share this post Link to post Share on other sites
lynnmor 8,642 #2 Posted March 7, 2016 The clevis where the cable ball end attaches was made in two lengths. See:Manual Share this post Link to post Share on other sites
DougL3 63 #3 Posted March 7, 2016 Correct. My 520 is hydrostatic with the filter on the left so it takes the long Clevis. I have the long clevis installed. Share this post Link to post Share on other sites
Shynon 7,543 #4 Posted March 7, 2016 1 hour ago, DougL3 said: I got the entire hitch kit from Wheelhorseman1000 and its on my 94 520H Did you contact the vendor I am sure he would be happy to help you out. Share this post Link to post Share on other sites
DougL3 63 #5 Posted March 7, 2016 No. Seeing as it's an exact copy of factory Wheel Horse parts, I figured I'd ask all the experts here about adjusting it correctly. Share this post Link to post Share on other sites
wheelhorseman 3,251 #7 Posted March 7, 2016 I sent you a pm but just use 1 link of the chain and you should be able to lift it as high as you need to. I include a two link chain for the hitch so it covers all possible applications and so you don't have the long (tiller) chain hanging down and rubbing the paint off. 1 Share this post Link to post Share on other sites
DougL3 63 #8 Posted March 7, 2016 Thanks Lowell! Pics in the AM if there's enough light before I leave for work, otherwise I'll post pics of me moving gravel tomorrow afternoon. Share this post Link to post Share on other sites
wheelhorseman 3,251 #9 Posted March 7, 2016 No problem, and remember you might have to loosen up the trunnion a little bit when you use just 1 link - just play with it until you get the results that you want. Share this post Link to post Share on other sites
DougL3 63 #10 Posted March 7, 2016 (edited) Hitch Edited March 7, 2016 by DougL3 Share this post Link to post Share on other sites
