WNYPCRepair 1,923 #1 Posted March 5, 2016 (edited) After going back and forth between searching for a front end loader and building my own, I've decided to give building my own a shot. If it goes badly, I may decide to buy one, LOL. But I think if I don't at least attempt to build mine, I will always wonder if I can. Since I love building things, I'm going to at least attempt it. Credit goes to those who went before me, and those who provided help to me and others in their build, I have learned a lot watching those projects. First was this topic: Then Andy built a mount for a Kwik-Way for his 522xi in this thread: There were other topics, but these are the two that stick in my mind Andy, and those who helped him have by extension, been an immense help to me. Without his excellent thread and those who helped him with measurements, etc., I probably would not have attempted this. Andy's dimensioned subframe drawing has been a huge help already. So, rather than hijack his topic, I will start my own here. To catch up on what I have done so far, mostly planning and questions, see the Picked up a Kwik-Way Loader for my 522xi topic above. Yesterday and today were the first real building activity. I cut and drilled the brackets to make the mid frame attachment to the tractor. These will be welded to the two 2"x2"x1/4" frame members that attach to the rear axle. Edited March 5, 2016 by WNYPCRepair 10 Share this post Link to post Share on other sites
WNYPCRepair 1,923 #3 Posted March 5, 2016 9 minutes ago, AMC RULES said: Hopefully, the entertainment won't be the boom arms snapping in half. 3 Share this post Link to post Share on other sites
DennisThornton 4,771 #5 Posted March 6, 2016 Lot of work! But I've got time to watch. And looking forward to it! 1 Share this post Link to post Share on other sites
Snowmobileaddict 403 #6 Posted March 6, 2016 Doc724 was a big help in getting my build going. Thanks again Doc! Can't wait to see how yours turns out Brian! If you haven't picked out a spool valve yet, Surplus Center sent me a catalog today in the mail and these (2) are a good fit for a garden tractor FEL application no float: http://www.surpluscenter.com/Hydraulics/Hydraulic-Valves/Directional-Control-Valves/2-SPOOL-8-GPM-PRINCE-MB21BB5C1-DA-VALVE-9-7862.axd with float detent: http://www.surpluscenter.com/Hydraulics/Hydraulic-Valves/Directional-Control-Valves/2-SPOOL-8-GPM-PRINCE-MB21GB5C1-DA-VALVE-W-FLOAT-9-7862-F.axd Not sure how much use I'll get with the float option. My valve came with it. For nearly $100 it's kind of a spendy option. 3 Share this post Link to post Share on other sites
WNYPCRepair 1,923 #7 Posted March 6, 2016 (edited) 2 hours ago, Snowmobileaddict said: with float detent: http://www.surpluscenter.com/Hydraulics/Hydraulic-Valves/Directional-Control-Valves/2-SPOOL-8-GPM-PRINCE-MB21GB5C1-DA-VALVE-W-FLOAT-9-7862-F.axd Not sure how much use I'll get with the float option. My valve came with it. For nearly $100 it's kind of a spendy option. Actually that is the one I had picked out. Some quick help from anyone with hydraulic knowledge. I'm getting ready to order pump, valve and cylinders. I know nothing about SAE connectors. The pump is SAE 10, the valve is SAE 8, and the cylinders are SAE 4 (or possibly 3/8" NPT), will this cause any issue when getting hoses made (or any other issue)? Edited March 6, 2016 by WNYPCRepair Share this post Link to post Share on other sites
Snowmobileaddict 403 #8 Posted March 6, 2016 You can get all sorts of sae reducers fittings to make what you have work. Northern tool or even tractor supply. Plus universalhoseandfittings.com is great for fitting up whatever you need on each end of a given custom hose. That's who I used for hoses. For oddball hose orders just make the order over the phone. Thats how how I ordered my hoses. 2 Share this post Link to post Share on other sites
WNYPCRepair 1,923 #9 Posted March 6, 2016 (edited) 6 minutes ago, Snowmobileaddict said: You can get all sorts of sae reducers fittings to make what you have work. Northern tool or even tractor supply. Plus universalhoseandfittings.com is great for fitting up whatever you need on each end of a given custom hose. That's who I used for hoses. For oddball hose orders just make the order over the phone. Thats how how I ordered my hoses. Cool, all hydraulics ordered except cylinders and hoses. https://www.surpluscenter.com/Hydraulics/Hydraulic-Cylinders/Double-Acting-Hydraulic-Cylinders/1-5x16x1-DA-HYDRAULIC-CYLINDER-WOLVERINE-WWXT1516-S-9-8770-16.axd That is the cylinder I am looking at, unless someone sees a problem My pumphttp://www.northerntool.com/shop/tools/product_200329712_200329712 And valvehttp://www.surpluscenter.com/Hydraulics/Hydraulic-Valves/Directional-Control-Valves/2-SPOOL-8-GPM-PRINCE-MB21GB5C1-DA-VALVE-W-FLOAT-9-7862-F.axd Edited March 6, 2016 by WNYPCRepair Share this post Link to post Share on other sites
squonk 43,982 #10 Posted March 6, 2016 I had trouble finding a pulley for that 1/2" !/8" key shaft. Ended up having someone make the key slot for me. Share this post Link to post Share on other sites
JPWH 6,368 #11 Posted March 6, 2016 16 minutes ago, squonk said: I had trouble finding a pulley for that 1/2" !/8" key shaft. Ended up having someone make the key slot for me. Northern tool and tractor supply carries them. I think they will special order whatever size you need.as well. Share this post Link to post Share on other sites
squonk 43,982 #12 Posted March 6, 2016 (edited) I looked at Norther tool. No 1/2" bore pulley listed with a 1/8" keyway. Plus I needed a 5" diam pulley. You have to be careful sizing the pump and what speed it's turning. The hydraulics may be too slow so you're sitting there all day trying to do a job or too fast that you can't really control movement well. When I built my PK loader, I sat down with a hydraulics guy and he figured out the pump speed based on the pump size, engine speed, cylinder volume and stroke. and how long I wanted it to take to raise the boom. There is a lot to consider. Edited March 6, 2016 by squonk 2 Share this post Link to post Share on other sites
DennisThornton 4,771 #13 Posted March 6, 2016 Brian, at first I thought this is going to be such a detailed and daunting task that I just wouldn't do it, I'd find something that was 75% or better there and mod or finish the rest. But now that I've had a chance to think about it, and well, all things considered, I still feel the same! But, you're not going to build this alone. Now I see that you are going to have so much help from so many very experienced builders that you just might build the best FEL ever! 2 Share this post Link to post Share on other sites
squonk 43,982 #14 Posted March 6, 2016 Just for the heck of it, here are some pics of my PK loader build. http://www.mytractorforum.com/200-power-king-economy-tractors/117842-loader-project.html http://www.mytractorforum.com/200-power-king-economy-tractors/125447-elvis-loader.html 4 Share this post Link to post Share on other sites
Snowmobileaddict 403 #15 Posted March 6, 2016 It's true, the 1/2" ID bore pulleys are a bit more rare than the other larger bore pulleys. You need one in the neighborhood of 6" and it needs to take a B-section v belt (same as a 5L) McMasterCarr has a couple that fit the bill. Here is one, McMaster part no. 6204K32 You'd probably run the throttle at 1/2 to 3/4 throttle to keep the hydros from getting too bouncy or jerky. 1 Share this post Link to post Share on other sites
squonk 43,982 #16 Posted March 6, 2016 You will notice that pulley from Mc Master does not come with a key way cut for 1/2" bore. That's what I kept running into. These pulleys have one set screw and a standard ANSI keyway. 1/2" bore sizes do not have a keyway. 1 Share this post Link to post Share on other sites
Snowmobileaddict 403 #17 Posted March 6, 2016 Yeah. No key way. You'd have to drill a small shallow divot or similar into the pump shaft for the setscrew to land on and better secure the pulley. 1 Share this post Link to post Share on other sites
Snowmobileaddict 403 #18 Posted March 6, 2016 McMaster also has split taper and QD bushings with keyways to adapt a b section pulley to a keyed 1/2" D shaft. They just cost a bit more because you're buying 2 parts. The bushing and the smooth bore pulley 1 Share this post Link to post Share on other sites
DennisThornton 4,771 #19 Posted March 6, 2016 1 hour ago, squonk said: Just for the heck of it, here are some pics of my PK loader build. http://www.mytractorforum.com/200-power-king-economy-tractors/117842-loader-project.html http://www.mytractorforum.com/200-power-king-economy-tractors/125447-elvis-loader.html You realize that the FEL and combo PK/FEL is only AWESOME! That FEL would look SO good on my PK! 2 Share this post Link to post Share on other sites
WNYPCRepair 1,923 #20 Posted March 6, 2016 (edited) 1 hour ago, squonk said: Just for the heck of it, here are some pics of my PK loader build. http://www.mytractorforum.com/200-power-king-economy-tractors/117842-loader-project.html http://www.mytractorforum.com/200-power-king-economy-tractors/125447-elvis-loader.html Looks great Mike Well, I ordered the cylinders, hope they work, as they were not cheap. Edited March 6, 2016 by WNYPCRepair 1 Share this post Link to post Share on other sites
Snowmobileaddict 403 #21 Posted March 6, 2016 Do the PF plans suggest using (4) identical cylinders? Or slightly longer ones for the boom versus the bucket? 1 Share this post Link to post Share on other sites
WNYPCRepair 1,923 #22 Posted March 6, 2016 (edited) 4 hours ago, Snowmobileaddict said: Do the PF plans suggest using (4) identical cylinders? Or slightly longer ones for the boom versus the bucket? They show 4 identical cylinders. I had considered the same thing, that I didn't need the same length or the same stroke, but I finally just ordered 4 of the same. I had to move the mounting holes at the mid attach point down about an inch and a half, and fill in the old ones. I was sloping down from back to front about 1 1/4" in 4 feet. I am still sloping down about 3/8", but I don't suppose it is that critical. Didn't turn out too bad considering my limited welding experience. Then I mounted it to check fit, and saw that I have a tight fit between the cross support for the pedestals and the motion control pedal bracket. I have the cross support back at 11 1/2" (instead of the 12 3/4 in Andy's subframe drawing) and only clear by about 1/4". Sorry the picture is a bit crooked, I was laying on the floor, couldn't get a good angle. The mid mount, clipped into the mid tach-o-matic A shot of the subframe with the 3/4 round stock cut to length and welded in I have a piece of angle iron tacked front and back to keep it square until I weld it all up. What are the chances that I would just happen to have two pieces of angle iron the exact length I needed just laying around? I was shocked. Everything is just tacked at this point, except the round stock. The rear axle mount. Mine stick farther out the back than Andy's, I have plans for those ends which I'll get into later. Oh, and the 2" x 2" square stock is only 1/8" thick, not 1/4" like I thought. I would have liked to use 3/16" at least for those, but I used what I had on hand. If I think it is going to be a weak point, I can always add a length of 1 1/2" angle iron on each side to stiffen it up. Now unfortunately, I am at a stopping point. I need the U Bolts for the rear, and the steel for the pedestals. Edited March 6, 2016 by WNYPCRepair 3 Share this post Link to post Share on other sites
Snowmobileaddict 403 #23 Posted March 6, 2016 Extra long subframe rails.... Quick release suitcase weight bracket or other counterweight solution? Lookin good! 2 Share this post Link to post Share on other sites
WNYPCRepair 1,923 #24 Posted March 7, 2016 (edited) 2 hours ago, Snowmobileaddict said: Extra long subframe rails.... Quick release suitcase weight bracket or other counterweight solution? Lookin good! You nailed it, but it will be able to do more than just weights. Trailer hitch, for one. Maybe even a 3 point hitch, though I really have no need for one, so I may not bother. I think to start I am just going to make a platform for cement blocks, since I have the blocks already. Edited March 7, 2016 by WNYPCRepair Share this post Link to post Share on other sites
DennisThornton 4,771 #25 Posted March 7, 2016 Holy cow Brian! Slow down! I said I'd have time to watch but geese! And you filled in those holes just fine for a newbie! I'd want confirmation but I'm thinking that 1/8" box tubing is pretty darned stout for what you are doing underneath. 1 Share this post Link to post Share on other sites
