Duff 206 #1 Posted December 9, 2008 Butch wrote: "I guess this one attaches to the mid and front attach a matic? The one for my 314 uses the middle and back. Will either one work on either tractor? " Hi, Butch, Thought I'd try to answer you here since the photo gallery is for pictures only. Based on the length and location of the lift bracket, I think this will hook to the front attachamatic. I never tried hooking it up before I restored it, but when I asked the fellas back when I was bidding on it someone said it would fit the newer series tractors even though it was made in '76. Experts, advice please? Duff :hide: Share this post Link to post Share on other sites
Butch 194 #2 Posted December 9, 2008 Thanks Duff! I was wonderin where the page went! This looks much different than mine. I also don't see an arm but can the blade be turned left and right? I can't tell by the pic but yours might even be wider than mine. Butch Share this post Link to post Share on other sites
Rollerman 291 #3 Posted December 9, 2008 Duff & Butch...The 40" grader blade clamps into the "mid" attachment area. Clips in place just like a mower deck would. The 50" wide blades or "rear mount" go to the back like a snow plow would. Share this post Link to post Share on other sites
Duff 206 #4 Posted December 9, 2008 Duff & Butch...The 40" grader blade clamps into the "mid" attachment area. Clips in place just like a mower deck would. The 50" wide blades or "rear mount" go to the back like a snow plow would. Thanks, Stephen! That will save me some head scratching and probably bunged knuckles come spring when I go to hook the beast up! Butch, yes, there's an arm and it does pivot left and right. one "click" each way. The arm shows up better in the other shot over in the pictures gallery. Duff :hide: Share this post Link to post Share on other sites
rwilson 128 #5 Posted December 14, 2008 How tall is the blade? Just wondering if i could build one. Also I would like to know the measurment form the tach a matic pin to the pivot on the blade. Thanks. Share this post Link to post Share on other sites
TT-(Moderator) 1,170 #6 Posted December 14, 2008 How tall is the blade? Just wondering if i could build one. Also I would like to know the measurment form the tach a matic pin to the pivot on the blade. Thanks. The search feature here at RedSquare does work. Here's a very valuable pile of information about fabbing your own MM grader blade: http://www.wheelhorseforum.com/index.php?showtopic=1608 Share this post Link to post Share on other sites
rwilson 128 #7 Posted December 14, 2008 Thanks TT !! Share this post Link to post Share on other sites
