Shuboxlover 482 #1 Posted February 29, 2016 Well, I finally got around to putting the loader on my D-160 this weekend. Everything went great until I went to hook up the pump. First....does anyone have the part number for the belt? Second, it appears I am missing some parts for what I presume is the belt tensioner. Does anyone have pics on what is supposed to go here? And also any leads to where to get the stuff. Thanks 1 Share this post Link to post Share on other sites
pfrederi 19,018 #2 Posted February 29, 2016 Your set up looks similar but not the same as my WH (ARC loader) What model is yours Share this post Link to post Share on other sites
pfrederi 19,018 #3 Posted February 29, 2016 Gates need to improve the quality of the ink they use to mark their green belts Can't read the number on mine anymore. Seems to me I had to try a couple different sizes before I got the right one. My adjustment is done with a 3 in lg 3/8NC bolt with a nylock nut up through the bottom plate to the arm the pump is on. (Yours has a big rust spot around the hole). Yours looks like you could use a j bolt through the pump mount arm down and out through that hole. Share this post Link to post Share on other sites
Shuboxlover 482 #4 Posted March 3, 2016 Can someone maybe get me a pic of this? I'm thinking of a bolt with a knob out the bottom, a threaded trunion in the adjustment hole...any thoughts? Share this post Link to post Share on other sites
82Caddy 851 #5 Posted March 3, 2016 I can grab you a picture of mine tonight (ark 550 on a D series). Share this post Link to post Share on other sites
Shuboxlover 482 #6 Posted March 3, 2016 PERFECT. ..THANK YOU! !! Share this post Link to post Share on other sites
82Caddy 851 #7 Posted March 4, 2016 So mine is similar to yours but not quite the same. I'm not sure if mine has been modified or what happened to it. There is just a bolt with two nuts on it that is used to tension the pump. Pivots on one side with a slot on the other that keeps the pump aligned. Hope that helps. Share this post Link to post Share on other sites
Shuboxlover 482 #8 Posted March 28, 2016 OK, I have the tensioner portion figured out, now....2 questions.... ARK model# 7-3050 1) Does anyone have a manual for this thing 2) What size belt do I need Thanks Share this post Link to post Share on other sites
pfrederi 19,018 #9 Posted March 29, 2016 My belt is I am pretty sure (the ink is really faint) Gates 6845. Now mine is on a D200 I do not know if the PTO Pulleys on the D160s (especially Onans with electric PTOs are the same Incidentally are you into early Ford Broncos?? Share this post Link to post Share on other sites
Shuboxlover 482 #10 Posted March 30, 2016 PERFECT on the Gates 6845!!! THANK-YOU!!! I should hopefully be up and running tomorrow night. And about the broncos....I'm not into them, but they are pretty cool. Share this post Link to post Share on other sites
pfrederi 19,018 #11 Posted March 30, 2016 13 hours ago, Shuboxlover said: PERFECT on the Gates 6845!!! THANK-YOU!!! I should hopefully be up and running tomorrow night. And about the broncos....I'm not into them, but they are pretty cool. It is your handle that got my interest...the early boxy Broncos are called "Shoeboxs" 1 Share this post Link to post Share on other sites
WHX?? 53,022 #12 Posted March 30, 2016 here but I like early Broncos but never knew that! My dad always had a Bronco or an IH Scout. Thanks for the trivia Paul. Share this post Link to post Share on other sites
Shuboxlover 482 #13 Posted March 30, 2016 Shuboxlover comes from my love of the tri 5 Chevy (55,56,57) oft called shoeboxes...it seems there are a number of car styles called that. I have a 56, my dad has a 55 2 Share this post Link to post Share on other sites
WHX?? 53,022 #14 Posted March 30, 2016 Nother interesting tidbit, never heard the chevs called that. I'll have to ask my son, he is way into the '50s chevs. You should be 57hunter then Shubox & have the trifecta ...don't know where we went wrong my dad was a Ford man Share this post Link to post Share on other sites
Shuboxlover 482 #15 Posted March 31, 2016 Thanks for all the help guys!!!!!!!!!!!!!!!!! I got everything back together tonight, drained the old oil, put new in and it lifts like a champ!!!! THANKS AGAIN!!!!!! 2 Share this post Link to post Share on other sites
WHX?? 53,022 #16 Posted March 31, 2016 Now go put it to work! Share this post Link to post Share on other sites
roadapples 6,985 #17 Posted March 31, 2016 14 hours ago, Shuboxlover said: Shuboxlover comes from my love of the tri 5 Chevy (55,56,57) oft called shoeboxes...it seems there are a number of car styles called that. I have a 56, my dad has a 55 Over the years I had four 55`s and a 56. Still have a 56 chevy panel truck that I drove for years. It`s not on the road now.. Share this post Link to post Share on other sites
