SylvanLakeWH 29,829 #1 Posted February 28, 2016 Lights on my C 105 simply stopped working. One day they worked...next they didn't. Everything else works fine. Fuse is ok. All connections appear to be good. Not an electrical type guy so any help appreciated. (My bright (pardon the pun) idea of "fixing" it is simple - go straight to the battery...but I have other things on my to do list...) Thoughts? Share this post Link to post Share on other sites
N3PUY 1,031 #2 Posted February 28, 2016 Maybe they burned out! 1 Share this post Link to post Share on other sites
Daddy Don 911 #3 Posted February 28, 2016 check the ground wire 2 Share this post Link to post Share on other sites
slammer302 2,156 #4 Posted February 28, 2016 may be a faulty switch. Get a test light out and check for power to the switch. 2 Share this post Link to post Share on other sites
N3PUY 1,031 #5 Posted February 28, 2016 Maybe "She took a Louisville Slugger to both headlights". 2 Share this post Link to post Share on other sites
SylvanLakeWH 29,829 #6 Posted February 28, 2016 2 hours ago, N3PUY said: 1 hour ago, N3PUY said: Maybe "She took a Louisville Slugger to both headlights". Maybe they burned out! Nope and nope...But thanks for the ideas... 2 hours ago, Daddy Don said: 2 hours ago, slammer302 said: may be a faulty switch. Get a test light out and check for power to the switch. check the ground wire THANKS! Will check. Share this post Link to post Share on other sites
AMC RULES 37,250 #7 Posted February 28, 2016 (edited) 9 hours ago, N3PUY said: Maybe "She took a Louisville Slugger to both headlights". Edited February 28, 2016 by AMC RULES 2 Share this post Link to post Share on other sites
rmaynard 16,694 #8 Posted February 28, 2016 Since both lights went out at the same time I wouldn't suspect the bulbs. If it's not the fuse, I would have to guess it's a bad ground. Since the lights are grounded through the hood, my guess is that the hood ground is bad. I'm not sure where the hood ground point is, but on earlier models it was through the pivot assembly. 5 Share this post Link to post Share on other sites
pfrederi 19,269 #9 Posted February 28, 2016 I started running a wire from one of the hood hinge bolts to an engine mounting bolt to assure a better ground. Put a disconnect in it so you can remove the hood if you need to. 3 Share this post Link to post Share on other sites
SylvanLakeWH 29,829 #10 Posted February 28, 2016 (edited) Thanks for all the input... Even baseball pointers... (although this emoji appears to only address the potential problem with the "tail" lights...) Edited February 28, 2016 by SylvanLakeWH Share this post Link to post Share on other sites
pfrederi 19,269 #11 Posted February 28, 2016 "You can trust your mother but not your ground" (old electrical saying) 1 Share this post Link to post Share on other sites
WHX?? 53,336 #12 Posted February 29, 2016 You guys all know that the first sigh of trouble with the lights on your horse trailer check the ground!! Share this post Link to post Share on other sites
608KEB 811 #13 Posted March 2, 2016 (edited) Related question to this topic. If my lights keep blowing the 3 amp fuse. What should I check? I have a 75 C-120 Edited March 2, 2016 by 608KEB Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,846 #14 Posted March 2, 2016 Found where the 101639 fuse is listed as SAE 20 but likely should be SFE-20 amp fuse for the lighting circuit. Not knowing the gauge of the wire maybe try a 10 amp fuse. Garry Share this post Link to post Share on other sites
608KEB 811 #15 Posted March 3, 2016 (edited) For some reason I thought the 3 amp fuse was what WH used to run the headlights and taillight. Edited March 3, 2016 by 608KEB Share this post Link to post Share on other sites
SylvanLakeWH 29,829 #16 Posted March 5, 2016 Yes fans! No ground issue. The PO threaded the wire THROUGH the hinge for the hood. Over time the rubbing motion at the hinge wore through the wire. Wasn't noticeable from the visible side. Cut, spliced and nutted together and all is good! Thanks again for the input!!! 1 Share this post Link to post Share on other sites
