stevebo-(Moderator) 8,607 #1 Posted December 7, 2008 I need to know if the 1981 and 1984 C175 are the same as far as the transmission etc. I am looking to buy the 81 as a parts tractor. Does anyone know the years that the c175 were made?? thanks- steve b ps I have 2 items for sale: 1. 42 inch plow set up 2. rear wheel weights 3. 42 inch mower deck 4. set of wheels and tires off 312-8 (rears are good fronts are not) 5. set of tire chains for 312 6. 1974 B80 complete and running with 8hp kohler I am in Danbury, CT. pm if you are interested. Share this post Link to post Share on other sites
Sparky-(Admin) 24,887 #2 Posted December 7, 2008 Are they hydro or 8 speed? If there 8 speeds they will interchange. If their hydros the 84 will have an Eaton 1100 tranny. The 81 tractor was the year they swapped out to Eaton and stopped using Sundstrand trannys so I think some early 81's have Sundstrands and the later 81's had Eatons. Mike........ Share this post Link to post Share on other sites
stevebo-(Moderator) 8,607 #3 Posted December 7, 2008 Mike, They are both hydros. I understand that the eaton is a stronger tranny than the sunstrand, is that correct ?? Share this post Link to post Share on other sites
Sparky-(Admin) 24,887 #4 Posted December 7, 2008 Ok. I was wrong. The 1980 C-175 was the year they swapped out to Eatons over Sundstrands. Sorry Both tractors your lookin at should have Eaton trannys. The C-175 was made from 1980-84. Mike.......... Share this post Link to post Share on other sites
Michael Bullington 5 #5 Posted December 7, 2008 Model Year Type Engine Spec 01-17K801 1980 C-175 Twin 8 Speed Kohler KT17-24125A 01-17KE01 1980 C-175 Twin Automatic Kohler KT17-24125A 01-17KS02 1980 C-175 Twin Automatic Kohler KT17-24125A 01-17K802 1981 C-175 Twin 8 Speed Kohler KT17S-24143 01-17KE01 1981 C-175 Twin Automatic Kohler KT17-24125A 01-17K803 1982 C-175 Twin 8 Speed Kohler KT17-24200 01-17KE02 1982 C-175 Twin Automatic Kohler KT17-24200 11-17K801 1983 C-175 Twin 8 Speed Kohler KT17S-24223 01-17KE03 1983 C-175 Twin Automatic Kohler KT17-24223 11-17KE01 1984 C-175 Twin Automatic Kohler KT17S-24223 Share this post Link to post Share on other sites
stevebo-(Moderator) 8,607 #6 Posted December 7, 2008 that is great, thanks !!! Share this post Link to post Share on other sites
