russellmc301
project rusty
953 nut
The important thing is that you are pleased with the outcome. Some of the machines you see will be too nice to work and enjoy, others just look presentable; those are the ones who's owners are smiling!   :D
russellmc301
that is true i guess i'm to much of a perfectionist:techie-eureka:
russellmc301
what is the sand paper like running board stuff called?
Retired Sparky
I read here that somebody went the a slate board shop for the grip strip material you are looking for.  Another place to look is a store that handles industrial safety products. I can't help you more than that. I've been following your progress.  Keep up the good work. B)
953 nut
It is called "Skid Guard" and you can buy it from Ace Hardware, Lowe's, Home Depot and others.
russellmc301
i got the lift bar today in the mail 20.00 at the door 10.00 for the bar and rest for shipping
russellmc301
she is all painted and siting waiting to go her maiden test drive.
it looks great ill see if i can get a few pictures of it. all the wiring is fixed with the help of a friend, he said it was screwed up past fixing so he just re wired everything:ychain:
953 nut
:wwp:
dells68
What happened to the pics?  I just saw you're starting a 400.  I'd like to see pics of rusty completed:wwp:.
russellmc301
with a few stall mates, the front tire on the c-160 is about the same size as the back on rusty:ychain:. she is on wagon and riding around duty:auto-dirtbike:
i was just coming over to put some pictures in. i have other pictures but i can't find them. she has a name tag so the other horses could get to know her:banana-rock:
Edited by russellmc301
callum12
On 18 February 2016 at 1:17 AM, russellmc301 said:
well i'm restoring it and i might add some mods to it but noting extreme... i think :)
any pic of your a-800? did you do any cool things to it?
hello, sorry I'm a bit late on the reply! must have missed your post.
yes I've done quite a bit to mine, here's a picture:
your's has come out really well! i'd love to see a photo of her out in the sun doing her duties.
Callum
russellmc301
that cool how did you mount that weight bracket? i want to make a bumper for mine.
  • Similar Content
    • Rugerhound
      By Rugerhound
      Greetings!
      I have a non-Wheel Horse tractor (Craftsman 14 HP Briggs OVH) , but the part appears to be common to the Briggs & Stratton Engine rather than a Craftsman part.  (See the photo -  The connector and pins I need are circled in blue)
      I also have a 1977 Wheel Horse A-100 that needs a tail light lens & bulb.  (A complete tail light assy would be fine!)    Anyone got any idea what the Peterson part number is for the tail light for the model I have?
      Thanks!!
      Regards,  Pete
    • Rugerhound
      By Rugerhound
      Greetings everyone!
      I'm a new member to this forum and a new Wheel Horse A-100 owner.  I'd been looking for an inexpensive fixer-upper riding lawnmower to make my yardwork a little easier for an aging fellow like myself.   Snagged this A-100 for $250 that's in really decent shape for the most part.  The mower deck has some problems however, but the actual tractor is in great shape.  Doesn't look as though it was used much, and still has all the original tags on the Briggs  & Stratton stickers on the housings.  Engine sounds fine but the needle isn't shutting the fuel off properly, so it runs rough until it's revved up a bit.   The pedals have scarcely any paint worn from them.   Quite remarkable for a '77!
      So I have one of the blade shafts bound up, another that doesn't feel all that nifty.  I don't know if those bearings are sealed, or whether anyone might be able to clean 'em up and repack them for continued use.  Pulleys are in rough shape but I may be able to salvage them.    Any info on the bearings in the mower deck would be very helpful!   (Including recommended grease type, etc.)
      Also it needs a key... The Ignition switch is an INDAK 103991 which appears to cross to a Toro.   New switches are available, but does anyone know if it's possible to just purchase a replacement key?
      I'm guessing it takes typical non-detergent 30W oil...  It's a '77 model Briggs & Stratton 10 HP.  (Model 251707, code 77040412)  What fluid does the gearbox take?
      Thanks!!
      Regards,  Pete (Aka Rugerhound)
