T-BONE 1 #1 Posted February 14, 2016 So I installed a used transmission and have went threw 2 filters and am now on my third. When I start it up you can hear the faintly the pump running like when the mower/blower is raised or lowered all the way. The 2 previous filter the seal blows out and transmisssion oil pukes out ever where. I noticed on the 3 filter that it expabds to the point where the paint comes off. Any ideas. It seems to blow out after about the 3 time taking it out. Can the relief valve be adjutsed? Thanks for your help in advance. Share this post Link to post Share on other sites
squonk 46,139 #2 Posted February 14, 2016 Any chance some hyd lines are crossed? If I remember right the filter is on the return end of the system. What kind of filter are you using? The Toro filter is built pretty cheaply and can't take much abuse. Share this post Link to post Share on other sites
T-BONE 1 #3 Posted February 14, 2016 Napa 1410. 10w30 oil. Canadian replaced a hard line with a soft line due to fitting was stripped Sorry. I had to replace. Share this post Link to post Share on other sites
Phatboy 566 #4 Posted February 14, 2016 As Far as i know there should not be that much pressure because filter is on a return not a pump feed.. I would look at one of the manuals posted here to see if the lines are connected properly to the corresponding connector,, just my thoughts ,, i hope you get it straightened out buddy.. Share this post Link to post Share on other sites
T-BONE 1 #5 Posted February 15, 2016 U think I may have the lines reversed?? Share this post Link to post Share on other sites
cleat 8,944 #6 Posted February 15, 2016 It is on the return line to the sump. If the line from the filter to sump was blocked it would effectively then see full hydraulic pressure. Make sure the line from the filter to the sump is clear and not blocked by debris especially since you said it was a used transmission, it may have sat open at one time. This line runs from the filter around the front of the transmission and ties in front and center in the hydro unit itself. Make sure also that this line has not gotten pinched somehow. Share this post Link to post Share on other sites
WNYPCRepair 1,924 #7 Posted February 15, 2016 9 minutes ago, cleat said: It is on the return line to the sump. If the line from the filter to sump was blocked it would effectively then see full hydraulic pressure. Make sure the line from the filter to the sump is clear and not blocked by debris especially since you said it was a used transmission, it may have sat open at one time. This line runs from the filter around the front of the transmission and ties in front and center in the hydro unit itself. Make sure also that this line has not gotten pinched somehow. He said the hard line had been replaced with a soft line. I assume he means the previous owner spliced in a piece of hose with clamps. Is it possible the hose is flattening enough to raise the pressure? Share this post Link to post Share on other sites
cleat 8,944 #8 Posted February 15, 2016 Sorry, I missed that, but same thing really, just make sure line is clear and not kinked. If you disconnect it at the filter, you should be able to blow into the line feeding back to the transmission to ensure it is clear. Share this post Link to post Share on other sites
T-BONE 1 #9 Posted February 15, 2016 I will have a look. The soft line is a proper hydrolic line with fittings. Hopefully it's the right size. Share this post Link to post Share on other sites
WNYPCRepair 1,924 #10 Posted February 15, 2016 1 hour ago, T-BONE said: The soft line is a proper hydrolic line with fittings. So much for my theory. Share this post Link to post Share on other sites
T-BONE 1 #11 Posted February 15, 2016 I took the line of that was made and couldn't blow through it. The outside line of the filter that goes to transmission under the seat. I took the entire hose off and then could blow through it but it was hard. Here are some pics. What size is the original hard pipe. Share this post Link to post Share on other sites
cleat 8,944 #12 Posted February 15, 2016 I am in the house right now but I think the original is a 3/8" tube. Should be pretty easy to blow through. I can quite easily blow through the 1/4" fuel line from the tank to the fuel pump. Any restriction in that line could cause all sorts of issues with the filter. Share this post Link to post Share on other sites
T-BONE 1 #13 Posted February 15, 2016 I'll get on made a 3/8 made up tommorw. Share this post Link to post Share on other sites
cleat 8,944 #14 Posted February 21, 2016 did you get this issue resolved ? Share this post Link to post Share on other sites
T-BONE 1 #15 Posted February 21, 2016 I changed out 1/4" hose to 3/8". Still kinda winding sounding. Haven't had a really use it since. I have bought an extra filter just in case. Share this post Link to post Share on other sites
wolfden 0 #16 Posted February 22, 2016 Is the dip stick blowing out as well? are you sure you are using a "like kind" oil filter? toro # 79-5270 we use NAPA #1521. also check the rubber lines to the lift cylinder control valve, according to the fluid flow chart it looks like the fluid goes through this first, if one of those lines is clogged or collapsed it could cause a redirection of pressure. Hope this helps good luck. Share this post Link to post Share on other sites
T-BONE 1 #17 Posted February 23, 2016 I am using Napa 1410. Share this post Link to post Share on other sites
squonk 46,139 #18 Posted February 23, 2016 The 1521 is an engine oil filter. You need the 1410 which is a true hyd. filter Share this post Link to post Share on other sites
T-BONE 1 #19 Posted February 23, 2016 So I am using the correct one then Share this post Link to post Share on other sites
