rhamm17 3 #1 Posted February 13, 2016 I am finishing up a complete restoration of my C-161. Three years ago I removed the metal ID tag by drilling out the two rivets. I took pictures of every piece of this tractor to assist with re-assembly but inadvertantly failed to note the exact location of this ID tag. Does anyone here know where this was originally located? I cannot find original two rivet holes and think I replaced a damaged 'tower' assy from on off EBay with one that has no similar rivet holes. This is the last piece remaining in the restoration. Thanks! Share this post Link to post Share on other sites
ericj 1,579 #2 Posted February 13, 2016 I've seen them on the edge of the left side cover towards the motor. down under the battery, areas hope this helps and good luck maybe somebody can ad a picture and of course we'll need pictures of it completed eric j 1 Share this post Link to post Share on other sites
rhamm17 3 #3 Posted February 13, 2016 Here is the C-161 restored 100% with every piece disassembled, sandblasted, primed and painted. Awaiting decals which go on after I buff out the hood paint in warmer weather and, of course, the ID tag. 2 Share this post Link to post Share on other sites
rhamm17 3 #4 Posted February 13, 2016 wrong tag above! Share this post Link to post Share on other sites
c-series don 10,637 #5 Posted February 13, 2016 They can also be located under the dash on the plate that has the amp meter. It should be in the middle and at the top of the plate. Share this post Link to post Share on other sites
Molon_Labe 731 #6 Posted February 13, 2016 (edited) C-161 Automatic location Edited February 13, 2016 by Molon_Labe info 1 Share this post Link to post Share on other sites
Pullstart 68,378 #7 Posted February 13, 2016 I have 2 C-101 8 speeds and they have two different locations. On this pic, you can barely see it just behind the engine on the forward facing big of the dash tower and on this pic it's directly under the dash panel. 1 Share this post Link to post Share on other sites
ericj 1,579 #8 Posted February 13, 2016 it would go on the panel that is missing on the edge that faces the motor eric j Share this post Link to post Share on other sites
rhamm17 3 #9 Posted February 13, 2016 Hi All, Thanks for all the input. I just found the original mounting location which is low on the left side mounted right off the left foot rest facing forward, mounted vertically. Very obscure location. I will mount it as shown above on the front dash panel as this is much more readable. This have been very helpful....thanks again! Bob Hammond 1 Share this post Link to post Share on other sites
doc724 925 #10 Posted February 14, 2016 The location depends on what year you have (if you really want to keep everything original). The 1978's had the tag mounted on the tower facing the motor like in Pullstart's top photo. The 1979's had them under the control panel like in Molon_Labe's photo. 1 Share this post Link to post Share on other sites
Horse46 519 #11 Posted February 15, 2016 Mine were both below the regulator, C-101 1978 and I almost sure the C-161 was a 1978 Share this post Link to post Share on other sites
TDF5G 2,073 #12 Posted February 17, 2016 My '79 C-121 is below the dash also. Share this post Link to post Share on other sites
