engineguy63 238 #1 Posted February 12, 2016 I picked up some wheels for my Suburban..............from a Forum member (THANKS TONY!!) they have seen some weather and we where not sure they were off a suburban, but MUCH better than what I had!!!!! I am taking them tomorrow to my friends shop to have them sand blasted. I know they will need bearings, and I was hoping the bearings were a simple hardware store/tractor supply item and not something exotic. Is there a part # for a good replacement I should be looking for?? If anyone can clarify how the get setup...washers, cotter pins etc that would be great..........I'd like them as right as I can get them with out getting silly Thanks!! Share this post Link to post Share on other sites
Racinbob 12,796 #2 Posted February 13, 2016 The originals are 1 3/8" od x 3/4" id flanged bushings. I put in sealed bearings of the same size. They are all over on EBay and I'm sure other places. Since the bearing is sealed I won't have to pump grease in. My 400 won't see real work so I should be fine. Try the fit. You probably will want the shim them. They are held on with external snap rings. Share this post Link to post Share on other sites
engineguy63 238 #3 Posted February 14, 2016 The initial clean up of one.........looks like it is going to end up being VERY presentable!! 3 Share this post Link to post Share on other sites
