chorusguy 227 #1 Posted February 10, 2016 have c160's with K 321's i believe. 16 hp K series engines. I saw on craigslist a 16 hp magnum for a pretty good price. They look very similar. Can someone tell me what is different? Thanks Share this post Link to post Share on other sites
roadapples 6,983 #2 Posted February 11, 2016 The magnum has no points, not sure what else may be different. I have both and don`t see any difference in the way they work...The 16 horse is K341, K321 is 14.. Share this post Link to post Share on other sites
JAinVA 4,638 #3 Posted February 11, 2016 1 hour ago, chorusguy said: have c160's with K 321's i believe. 16 hp K series engines. I saw on craigslist a 16 hp magnum for a pretty good price. They look very similar. Can someone tell me what is different? Thanks The Magnum has a different starter,and flywheel than the K series.The throttle and choke are connected differently than the K series,at least the the ones I have are different. Internally I have read that the crank counter weights are lighter requiring the balance weights be used.Because the Magnum series doesn't use points the normal K ignition switch will not shut off the engine.The ignition has to go to ground as opposed to switched to open.The Magnum is a good choice to replace a K if you know what needs to be addressed to make it run and shut off.Engine swaps are what keep these old girls running.I have a 16 K in place of the 220 Onan that came in my 520h so if the price on the Magnum is reasonable and it is in good shape go for it.Luck,JAinVA 4 Share this post Link to post Share on other sites
chorusguy 227 #4 Posted February 11, 2016 thanks guys. I don't actually need a new engine yet, but it did spark my curiosity. Very good information. Share this post Link to post Share on other sites
otrelwood 32 #5 Posted February 12, 2016 if its a good buy get it for a spare they are getting hard to find and expensive Share this post Link to post Share on other sites
wrightorchid 261 #6 Posted February 12, 2016 A good engine, worth getting if the price is right. Share this post Link to post Share on other sites
