trowbri1 5 #1 Posted February 9, 2016 Noticed this problem yesterday while doing some work outside. The trctor would start right up but when I'd put it in gear it would stall and shut off. It's never done this before. Now this evening I went out and it fired right up, I turn on the headlight switch and it died and now it wont start. Acts like the battery is dead but the battery is fine, has been on the trickle charger all winter....who could this be?? Share this post Link to post Share on other sites
953 nut 62,053 #2 Posted February 9, 2016 Did the lights actually illuminate? I am thinking you may have a short to ground on the wires to the lights and it is killing the ignition. As you also mentioned the direction selector killing it that would be a good place to start looking for a wire out of place. Let us know what you find. Share this post Link to post Share on other sites
trowbri1 5 #3 Posted February 9, 2016 The lights didn't turn on. Thanks! Share this post Link to post Share on other sites
daveoman1966 3,873 #4 Posted February 9, 2016 Ignition switch gone south...? ? After all, it's only been in svc for 45 years or so. 1 Share this post Link to post Share on other sites
Horse46 519 #5 Posted February 14, 2016 You said first that when you put it in gear it cut out, is there a safety cut out switch on the clutch? It could be a dirty connection there, a bad earth can cause all sorts of gremlins to manifest . Share this post Link to post Share on other sites
